Cannot Spin The Tires
Old Apr 26, 2008 | 04:03 AM
Dr Steve's Avatar
Dr Steve
Default Cannot Spin The Tires
Although it is the kind of thing that a 16 yr old would do, I could not resist. Tried to spin the tires from a full stop with my 07 vert. Barely a chirp. No smoke, no fireworks, no black patch. TC and all the other computer stuff was off. Trans was in S mode, and paddle shift in 1st gear. Had a '59 Pontiac when I was a kid that could "patch out" with ease. Not that this is an imprtant feature, but I want to be rasured that my car aint broke. Bought it new, an '07, z51, never abused or raced (except for this episode). Your thoughts?
Old Apr 26, 2008 | 05:47 AM
bolivar's Avatar
bolivar
I think you are spinning the tires. Runflats don't squeal.
Old Apr 26, 2008 | 06:47 AM
VETTAMOUS's Avatar
VETTAMOUS
St. Jude Donor '11-'12, '14
the a6 sometimes starts in second gear. get the trans tune and it will drop to first every time.
Old Apr 26, 2008 | 08:17 AM
vette-time's Avatar
vette-time
my 07 will light the tires up from a stop make sure you are in first gear.
Old Apr 26, 2008 | 08:42 AM
Deja Vu 2 U's Avatar
Deja Vu 2 U
From: Somerset Kentucky... Life's Abundant For Those Who Believe
i'm with you
my tires really do not spin or make a noise
even with it in s and paddle shift in 1st and pedal to the metal... maybe ya need to have a manual shift and get the revs up and pop it in 1'st...
Old Apr 26, 2008 | 09:20 AM
mksz51's Avatar
mksz51
Learn to power brake - abusive but effective. Right foot on gas, left foot on brake - modulate both (right down, left up) until you reach the point where the front brakes are "holding" the vehicle back and the rear brakes are "overpowered" by the engine. Come over to eastern Iowa and I'll be happy to give you a tutorial.
Old Apr 26, 2008 | 09:40 AM
jonparks's Avatar
jonparks
Ok, here is the procedure. This will work. One foot on the break one the gas... too much traffic I can't pass. ... sorry couldn't resist. run the tack up to about 1400rpms or so. Then let off the break and floor it at the same time. I can assure you this. You will be smook'en tire!
Old Apr 26, 2008 | 09:42 AM
wallyj's Avatar
wallyj
Last week I took my 08 A6 out for a little testing. Used my G-Tech acceleraometer to get a few 60ft and 0-60 mph times.
Trans in S, Traction Control in Comp mode.
From Idle matting the throttle gave me very minimal wheelspin. As stated above, these runflats are pretty quiet spinning so you could barely hear it. Car bogged a bit (as evidenced by the lazy 2.05 60 ft times) then really flew. 0 to 60 in 4.09 twice in a row.
I'm guessing the torque management is what causes the bog.
Just cause I also enjoy a little tire smoke, I braked it at got them spinning before letting go. Smoked them thru 1st and second.
Old Apr 26, 2008 | 09:48 AM
Michael Hunter's Avatar
Michael Hunter
I have an 07,A6, and one day I was fooling around and stopped, put in Competative Driving Mode, Clicked it down to 1st gear, stood on it, and left a smoke show. They definately squealed and I had to get out of it for them to stop.
Old Apr 26, 2008 | 10:04 AM
freyke's Avatar
freyke
Cut a tight left in 1st, w/WOT... I'm sure you'll remember the experience.
NYC6's Avatar
NYC6
No spin, no smoke, just rapid forward motion! that is a perfect holeshot! Drag racers spend good money to do that. People have commented about my cars getting out of the hole like it does. Besides it saves me greenbacks in tires.
Old Apr 26, 2008 | 10:13 AM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
I can get mine to spin going from 2nd into 3rd.
Old Apr 26, 2008 | 10:21 AM
aquaman's Avatar
aquaman
I think it may be the Active Handling that stops you from spinning. Try pushing the button once to turn it off and see what happens. I was at a drag strip trying to do a burnout in the water and had forgot to turn AH off. I couldn't even spin the tires in water.
Old Apr 26, 2008 | 10:28 AM
aquaman's Avatar
aquaman
I think it may be the Active Handling that stops you from spinning. Try pushing the button once to turn it off and see what happens. I was at a drag strip trying to do a burnout in the water and had forgot to turn AH off. I couldn't even spin the tires in water until I turned it off.
Old Apr 26, 2008 | 10:30 AM
aquaman's Avatar
aquaman
On the other hand, I can't seem to run a computer either!!
Old Apr 26, 2008 | 10:32 AM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
tc off ah off
that should do it
if not, get , then 410, s/c, headers, cam and heads and a tune
thatl do it too
Old Apr 26, 2008 | 11:10 AM
Silver99v6's Avatar
Silver99v6
It cuold be an experience that you dont want to remember.
To Cannot Spin The Tires
Old Apr 26, 2008 | 11:53 AM
c6 batmobile's Avatar
c6 batmobile
look at my avatar I have an auto. They will smoke and burn and scream you just have to do it right.
Old Apr 26, 2008 | 12:02 PM
danl72's Avatar
danl72
I haven't tried it yet, but I will. I know it is possible because a friend did it in his Vette. Everyone is right, tc has to be off.
Old Apr 26, 2008 | 12:23 PM
RogerC6's Avatar
RogerC6
From: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
[QUOTE=Dr Steve;1565192436]Although it is the kind of thing that a 16 yr old would do, I could not resist.
