Window indexing problems
What happens is every time I start/stop my car, the window indexes up/down/up/down non-stop until I either put it into drive or it stops after doing it for a minute when I lock the car. Anyone have any thoughts? I have already tried to window index it again and no help. Also, the power to the door died yesterday and I had to use the latch to open the door. Mysteriously worked again this morning but window indexing problem is still there. I am going to take it to the dealer this weekend, is this something I can just do a walk in for or do I need to make an appointment?
Just a guess, but it sounds like a flakey door release button, inside/out or a wiring problem.
Good luck
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Conti
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)Models: 2007-2008 Cadillac XLR2007-2008 Chevrolet Corvette ________________________________________ ____________________________________This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).___________________________ _____________ ___________________________________Condi tionSome customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.CorrectionDiagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.Parts Information Part Number Description10446243 Front Side Door Handle SwitchWarranty InformationFor vehicles repaired under warranty, use: Labor Operation Description Labor TimeN9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
(my bold emphasis)
(my bold emphasis)
