Screwed!
Old Jun 7, 2008 | 05:24 PM
Mu$cle's Avatar
Mu$cle
Default Screwed!
I was cleaning up the Z06 (which has only 850 miles) and noticed a sheetrock screw in the rear tire about an inch from the sidewall. I checked the length and it is through the tread. I left the screw where it is and made sure the tire pressure is correct.
As I interpret the tire warranty information, Goodyear will repair/replace the tire at their cost. Is my interpretation correct? Have any of you had experience with this warranty service? I realize that I have to use a Goodyear service facility that is authorized to service run-flat tires. Thanks.
Old Jun 7, 2008 | 05:30 PM
Vette_DD's Avatar
Vette_DD
Yes, they will. When I had a nail in the tire of my 05 coupe, there was not a GoodYear-certified shop anywhere close. I paid $35 to have a local shop repair the tire.
When it wouldn't hold because it was too close to the sidewall, I had to drive 45 miles each way to have a GoodYear dealer replace it. They did replace it and mount it free.
Old Jun 7, 2008 | 06:37 PM
rws.1's Avatar
rws.1
thanks for my learning of the day...
Old Jun 7, 2008 | 06:45 PM
rab488's Avatar
rab488
I don’t have a Z06 but I thought that Z06’s don’t have run-flats.
Old Jun 7, 2008 | 07:26 PM
Zymurgy's Avatar
Zymurgy
Moderator
They certainly do:
Front 275/35ZR-18
Extended Mobility, Goodyear Eagle F1 Supercar
Rear 325/30ZR-19
Extended Mobility = Run Flat
Old Jun 7, 2008 | 07:42 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I use Z06 runflats for street tires on my C6...the same as Zymurgy listed.
Old Jun 7, 2008 | 08:20 PM
bigdsz's Avatar
bigdsz
The C5 ZO6 didn't have run flats.
Old Jun 7, 2008 | 09:37 PM
GotVett?'s Avatar
GotVett?
Is the Goodyear warranty good for just the 1st year?
Old Jun 7, 2008 | 11:49 PM
Mu$cle's Avatar
Mu$cle
Per the Goodyear "Owner's Manual & Limited Warranty", "Any new Goodyear Extended Mobility Technology tire removed from service due to a covered warranty condition or rendered not repairable due to a road hazard injury during the first 2/32" treadwear or 12 months from date of purchase, whichever occurs first, will be replaced at no charge. Mounting and balancing are included. Repairable punctures will also be repaired at no charge during this period." Replacements are prorated after that with owner paying for mounting, balancing, tax and cost of puncture repair, if applicable.
Old Jun 12, 2008 | 06:46 PM
Mu$cle's Avatar
Mu$cle
I had the tire containing the drywall screw replaced today by the selling dealer. The good news is the Goodyear Warranty worked great (I never pulled the wallet out) and the dealer service was quick (about an hour) and no damage to the car. The bad news is the technician inspected the other tires and found a nail in the other rear tire. So, I'm back to the dealer tomorrow to replace that one. It's hard to believe the car has only 920 miles and already have two damaged tires. It wouldn't be so surprising if there were any houses under construction between my house and the main road. It's a good thing Goodyear's run flat have built-in road hazard coverage.
Old Jun 12, 2008 | 06:49 PM
phileaglesfan's Avatar
phileaglesfan
I know a few members had a problem with certain GY dealers so it may pay to look around. I didn't know about it when it happened to me though.
Old Jun 12, 2008 | 07:23 PM
BAMAGOLFER's Avatar
BAMAGOLFER
St. Jude Donor '06-'10-'11
You sure those tires aren't magnetic?
Old Jun 12, 2008 | 07:26 PM
BigSlick's Avatar
BigSlick
glad to see that GY stand behind there tires with no excuses...
To Screwed!
