Maximum G Force Reading
Old Jun 10, 2008 | 03:37 PM
  #41
YeeeeeHaw's Avatar
YeeeeeHaw
How can you tell if the reading is for left turn or right turn?
Old Jun 10, 2008 | 04:12 PM
  #42
nikic6's Avatar
nikic6
I don't think you can. It oply recalls the maximum reading since the ignition was turned on.
Old Jun 10, 2008 | 04:34 PM
  #43
jschindler's Avatar
jschindler
I've had three C6's since right after they came out. I told myself early on that I would not have the G meter up on my HUD. Trying for a new record through every turn sounds like a good way to wind up in a ditch - or worse. So I have no idea what the greatest G's I've turned is.
Old Jun 10, 2008 | 06:26 PM
  #44
Bobz08C6's Avatar
Bobz08C6
Originally Posted by NickMongo
10.1 Gs durng an overshoot of the 9G limiter during a dogfight in the F-16N.
Seems to me that's blackout territory even in a "g" suit.
Old Jun 10, 2008 | 09:37 PM
  #45
waldow's Avatar
waldow
St. Jude Donor '09
sorry about pic clarity- US 221 around Grandfather Mtn
[IMG][/IMG]
Old Jun 10, 2008 | 09:53 PM
  #46
YeeeeeHaw's Avatar
YeeeeeHaw
Good advise
Old Jun 10, 2008 | 11:17 PM
  #47
drlndrve's Avatar
drlndrve
[IMG][/IMG]
How the heck did you get this pic and drive at tbe same time?
Old Jun 10, 2008 | 11:50 PM
  #48
NORTY's Avatar
NORTY
A typical drive with the "Varmits..."
Old Jun 11, 2008 | 01:11 PM
  #49
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by Bobz08C6
Thanks. Good info. I'm not going to try this until I get to my local track with an instructor in the car with me in September.
Nannies?
Good idea. A good instructor will explain a lot more about the physics that you will get here. It's more complicated than it seems and not all that intuitive.
Nannies = Active Handling and Traction Control. They may slow you down just a little overall but they get you through the corners at higher Gs and could easily save you from a repair bill if not more. Once you turn pro then you can turn them off for the small decrease in total lap time.
Old Jun 11, 2008 | 04:44 PM
  #50
Larry/car's Avatar
Larry/car
I saw 1.2 G durring my high performance training at Spring Mountain. This was in a standard Corvette with the Z-51 option. This was noted with the recall feature, I could not tell you where on the circuit this happened, to busy driving.
