Ed Help Help Help!!!!
Old Jun 16, 2008 | 10:39 AM
Mark the Shark's Avatar
Mark the Shark
Default Ed Help Help Help!!!!
Everything on my 2008 went dead, had to have it towed to the dealer. They are blaming everything on the exhaust control switch I got from Ed at Pipedreams. GM tech said several modules are shorted as a direct result and nothing will be covered by the waranty. They are talking several thousand dollars!!! I don't really believe them but I don't know what I can do. Any ideas!!!
Thanks,
Mark
Old Jun 16, 2008 | 10:52 AM
Mark the Shark
anybody?
Old Jun 16, 2008 | 10:54 AM
JLargo's Avatar
JLargo
Old Jun 16, 2008 | 11:02 AM
OnyxC6's Avatar
OnyxC6
Thanks,
Mark
Take the switch off and go do another dealer
Old Jun 16, 2008 | 11:11 AM
TRR's Avatar
TRR
That's what I'd do. I keep my fuse in the car ready to change it out just in case something like that happens. I really don't think that caused your problem, but they could use that to screw you.
TRR
Old Jun 16, 2008 | 11:12 AM
KWIKC6's Avatar
KWIKC6
Should have removed it before you took it in.......
Old Jun 16, 2008 | 11:15 AM
ATC399's Avatar
ATC399
wow.....good luck...let us know the out come
Old Jun 16, 2008 | 11:17 AM
Mark the Shark
It was dead and I had to call roadside assistance. The dealer told me they already contacted GM tech assistance and they would know if I took anywhere else...
Old Jun 16, 2008 | 11:41 AM
Mark the Shark
Sorry to say I've been a lifetime suporter and have purchased nothing but GM products my entire life but if they refuse to repair this under warranty I will never purchase another!
Old Jun 16, 2008 | 11:48 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Not sure why you would not email or pm me directly,just happened to find this thread. Mild2wild installed as delivered really can't cause any of the issues you reported. It only acks as a fuse, so either the fuse is in or it's out. Please email me so I can find out your purchase info and how you had it installed leeacustoms@optonline.net
Old Jun 16, 2008 | 12:00 PM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
This is the same car that was dead last week and had both fobs locked inside. He reported then that his local dealer would not work on it.
Something is wrong here.
Old Jun 16, 2008 | 12:10 PM
TrackNoob's Avatar
TrackNoob
I heard that! He also had the wheels backwards, too, right?
WTF?
Old Jun 16, 2008 | 12:15 PM
matsarge's Avatar
matsarge
WTF?
yep, he appears to be the single most unlucky person on the planet, glad he doesn't live near me...
Old Jun 16, 2008 | 12:43 PM
Mark the Shark
Default Tracknoob you are correct, WTF
If you want to read here are the details:
Bought the car from Dave at Kerbeck last Nov.
Noticed the wheels were backwards. Dave S told me I could to switch them myself, which I did. Problem #1 solved.
Last week the keyfob would not work to open car. I had to go in through the hatch, which I did. I put the keyfob in the glovebox slot with no responce. So I went and got the other keyfob and tried that one. That one would not work so I tried that one in the glove box also. I was standing outside the car with the door open and both keyfobs inside when my son tried to get by the car with his bike. I shut the door to give him room and I was locked out. I'm sure you can imagine my reaction...
I had to call roadside, I was sure it was the battery. They came over and the driver had a great idea of fishing out the keyfob with a long rod. This worked because the window did not index. Problem #2 solved
I charged, disconnected and reconnected the battery, nothing worked. I called roadside again and like an idiot never thought of removing the exhaust switch. Now GM tech support is blaming the switch for everything and the dealer won't touch it until I agree to pay up! Which they say will be at least $1,000 but probably a lot more!
Now you know the whole story... WTF
Old Jun 16, 2008 | 12:44 PM
Bobz08C6's Avatar
Bobz08C6
It seems to me it is just a fuse/no fuse arrangement as mentioned above and if by some remote chance something did go wrong it would only affect that circuit anyway.
If another dealer won't fix it for you under warranty then it's time to call the GM 800 number and work your way up the food chain. Follow the process.
Old Jun 16, 2008 | 12:46 PM
Pipedreams's Avatar
Pipedreams
Email sent, you should need to remove the switch, appears the tech has no clue and you need to get one that does.
Old Jun 16, 2008 | 12:53 PM
danl72's Avatar
danl72
Somehow I don't think it is the M2W. Something else is going on there.
To Ed Help Help Help!!!!
Old Jun 16, 2008 | 12:58 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Since the dealership seems to have all the answeres. I would make them justify why and how this could happen. I think smoke is being blown here!!!!
Old Jun 16, 2008 | 12:59 PM
2008c6's Avatar
2008c6
Old Jun 16, 2008 | 01:15 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I wouldn't think a 'mild to wild' switch (properly installed) would cause this problem. I'd ask for something in writing that explains why the modification caused the problem.
TRR
It amazes me how many people suggest you attempt to defraud GM by de-modding the car. Argue the point if the modification didn't cause the problem but have some integrity....don't resort to committing fraud and stealing.
