operating temperature
Old Jun 28, 2008 | 08:59 AM
  #41
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by HOXXOH
I was just kidding of course. The real answer is yes you will get heat from the car heater. It will take longer before the thermostat opens and the coolant starts flowing with the stock stat than with the 160, but more than sufficient heat will be available for the interior so you won't freeze with either stat.
Actually, the coolant is flowing through the heater all the time, regardless of the thermostat being open or closed. It puts out heat very quickly.
Old Jun 28, 2008 | 10:31 AM
  #42
haljensen's Avatar
haljensen
A 160° T'Stat doesn't result in 160° coolant temp. but even if it did 160° water is hot enough for your heater to function.
Ever check the temperature of the hot water from your home hot water heater? I'll guaranty it isnt 200°.
Old Jun 28, 2008 | 06:02 PM
  #43
Pozzo's Avatar
Pozzo
This doesn't mean that it is hot enough to keep you warm on a cold day. Heat is being transferred to the outside. The heat lost may be greater than the heat gained.
