Test drove a C6
Old Jul 8, 2008 | 07:37 PM
  #41
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Quoted from a post by DTE
"It does not matter if your car is equipped with a 1-rib differential case, a 3-rib differential case or a million-rib differential case for the likelihood of transmission/differential case fracture to occur in that area due to metallurgical fatigue, deflection stress or excessive shock load events.
In all of these instances, there is still only 5 meager fasteners between the transmission-to-differential juncture where the greatest probability of fracture/breakage will occur. You can have any amount of differential case webbing count you want under the car, but the weak mounting point at the transmission extension housing still remains and is at risk, due to the light duty cast aluminum parts in that area.
In other words...a 1-rib case will fracture just as easily as a 3-rib unit would without the use of our product, because the small connection point at the transmission still has not changed and it's still weak- even though the differential case may be stronger by itself. "
Old Jul 8, 2008 | 07:49 PM
  #42
Gannet's Avatar
Gannet
St. Jude Donor '06
I would suggest you not only consider '08s, but also look hard at an '09. If you get pricing on an '09 from a Forum dealer like EVS Chevrolet you might be shocked at how small a price difference there is compared to an '08.
With an '09 you can:
  • Order exactly what you want
  • Do a Buyer's Tour
  • Get Museum Delivery
As to options, I'd strongly suggest NPP exhaust and the Z51 package. Coming from an S2000, you will greatly appreciate both. I'd also get the 3LT trim package. It has a lot of features that might not sound like much now, but which you will really appreciate after you own it.
Good luck!
