Window indexing problem
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual.
Window Indexing
This feature automatically lowers the window a small
amount when the door is opened. Then, when the door
is closed, the window will raise to its full up position.
If either window does not index properly, it could be due
to loss of power. Before returning to your dealer for
service, perform the power window initialize procedure
following.
Power Window Initialize
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
2-18
