Downshifting Help
Old Jul 28, 2008 | 10:22 AM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
Default Downshifting Help
From time to time, I'll be cruizing in 6th at about 1500rpm or so and want to drop into 4th directly. Problem is, I am so used to the old school 4 spd shifter that I end up in 2nd.....any tips to cure this old habit or is the shifter (the mechanical one ) contributing to this???
Old Jul 28, 2008 | 10:30 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Try this trick. Changing the position of your hand on the shifter when you make a particular shift helps. The shifter has a centering spring and you can guide it to where you need it to go.
For shifts first and second try putting your hand on the side of the shifter by gripping the right side of the shifter, palm facing left and knuckles pointing towards the passenger door.
For shifts third and fourth try putting your hand on top of the shifter with your palm covering the shift pattern on top of the **** and knuckles pointing to the roof.
For shifts fifth and sixth try putting your hand on the side of the shifter by gripping the left side of the shift ****. You'll need to turn your hand upside down for this one and press your palm little finger at the top) to the shifter and your knuckles should be facing the drivers door.
This little extra trick will help you guide the shifter without really thinking about it once you get comfortable with the technique. The way that you are shift currently is putting pressure on the shifter and pulling it all the way over and ending up in second. The spring does the centering but you are overcoming the centering motion and pulling it right down to second.
Old Jul 28, 2008 | 10:59 AM
Jim Nebraska's Avatar
Jim Nebraska
Have you had the car long? You'll get better at it the longer you have it and following Talon's advice will sure help. My MGW shifter helped a bit too....seems like the slots/shifts are more well defined. So the answer is to drive the car more often to keep improving. Not the worst thing in the world to do!
Old Jul 28, 2008 | 11:05 AM
Two007's Avatar
Two007
Default Change the Stock Shifter
Change the stock shifter to an aftermarket. I put a Calloway into mine. The centering spring is stronger. You just pull it out of 6th, let it pop itself into the "centering position" then gently pull it back into 4th. I have never had a missed shift after replacing my stock shifter. Same goes for 2nd to 3rd. You just push up on the shifter, it will slide right into 3rd without any effort at all.
Old Jul 28, 2008 | 12:08 PM
C2C6Z06's Avatar
C2C6Z06
Thanks Talon, I learned that for the upshifts and have been trying that on the downshifts, but miss the centering feel for 4th....
Jim, Not really that long - 2K miles and three months...I have already noticed a great improvement...
I guess I'll just have to drive more , ya know, practice, practice, practice
Old Jul 28, 2008 | 12:36 PM
talon90's Avatar
talon90
NCM Ambassador
Practice, practice, practice is right. Keep at it and you will get the feel for the center. The hand on top of the shifter as I described above will help you find fourth from fifth or sixth. That way you aren't putting any additional side load on the shifter such as pulling towards you. If you use just your fingers with the palm centered on the top of the shift you will definitely feel the center and then it is just a pull straight back in to fourth.
Old Jul 28, 2008 | 12:39 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Try this. Just push the shifter out of 6th, then relax all pressure and just pull down. The centering spring should do the work of putting the shifter right over the 4th gear gate. If you are trying to pull it over to 4th you are probably overshooting the gate. Less is more in this case.
Old Jul 28, 2008 | 01:05 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I’m not trying to be facetious but why skip-shift? I’d shift from 6th into 5th gear instead of shifting from 6th into to 4th.
Everyone has a different driving style to be sure but for me, 5th and 6th gears are 'over-drive' gears reserved almost exclusively for freeway or interstate driving...not for in-town driving where speeds seldom exceed 50 mph. I couldn't imagine cruising in 6th gear anywhere other than a freeway or interstate (5th maybe but not 6th).
Certainly practice makes perfect no matter how you shift.
Old Jul 28, 2008 | 01:16 PM
REVHIGH's Avatar
REVHIGH
The tips above will all help for sure. Here is a little modification to the tip that I use and it works for me.
When shifting UP to 5th and 6th, I have my hand on top of the shift **** and just apply a little pressure with my thumb as I move up.
I do the wrap from 6th to 4th a lot when I am coming into a freeway exit and if I want to rally accelerate...as adised above, stay on top of the **** in your fingers and pull out of 6th, let the centering spring settle you, using your fingers like a shock absorber...then down into 4th.
BTW, lose the stock shifter ASAP. I got tired of it real quick, sloppy. I instaled an MGW shifter and a heavy **** and it made all teh difference in the world
Old Jul 28, 2008 | 01:23 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
If you look in the stickies above, there is a post on how to race your car at the drags by "ranger." I'm not saying to go racing. I am saying that one of the things he recommends is literally sitting there with the engine off and practice your shifting.
It doesn't matter what method or trick you use, without the engine on, and with the handbrake on, there's an awful lot you can try out, and get used to.
Give it a shot!
PS I understand why you might (very) occasionally want to skip a gear, but otherwise I mostly agree with Wayne. That said, since the spring in the shifter with no extra effort centers on 3rd and 4th gears, moving the lever up from 6th should put you right in line for 4th. Try it. It'll slot into 4th every time.
Old Jul 28, 2008 | 02:05 PM
Cal Vert Man's Avatar
Cal Vert Man
Unless you want to spend the $$$$, I wouldn't change shifters. The one provided is quite good. Just follow the pointers from the previous posts, and soon you'll be going from 6th to 4th without thinking about it.
Stactic practice will help a lot . . .
Old Jul 28, 2008 | 02:27 PM
ZPirate's Avatar
ZPirate
2025 C8 of the Year Finalist - Modified
Practice! The more the better.
And maybe a MGW shifter for an even better feel and shorter throws.
Old Jul 28, 2008 | 02:31 PM
strawboss's Avatar
strawboss
right there it is!!!!!
To Downshifting Help
