Need New Battery
Old Aug 2, 2008 | 12:57 AM
knkali's Avatar
knkali
anyone put in an Odyssey battery in their car?
Old Aug 2, 2008 | 05:27 AM
keyplyr's Avatar
keyplyr
AutoZone Group 86 (reconditioned) battery: $19.99 w/ core exchange, 1 year replacement warranty.
Works for me
Old Aug 2, 2008 | 08:27 AM
GoVette's Avatar
GoVette
Default I have
Originally Posted by cclive
And CCA is measured at 0 degrees F, now I'd love to know how many here have ever started their Vettes when the battery and engine are at 0 degrees F.
During a winter trip last December I spent the night in Nebraska (can't remember the town) The next morning it was -5 without wind chill. Starting and driving was no problem. I did notice the display said "Traction Control Warming Up" so I drove slowly for about a mile and it went off. As a side note, I noticed on that trip that the car handles better without the traction control on in snow/icy conditions.
Old Aug 2, 2008 | 09:11 AM
beaversstonehaven's Avatar
beaversstonehaven
Originally Posted by sabooher
These batteries tend to lose their juice around 3 years, but since I've had zero issues with the Delco in my C6 I will more than likely replace it with a Delco.
Old Aug 2, 2008 | 09:33 AM
JPchevy's Avatar
JPchevy
If you're still under your 3/36k warranty, go to the dealer with the complaint of "vehicle intermittently requires jumpstarts and cranks slower than usual"
Also, when you get to the service drive, turn the engine off, but turn on the lights, turn the fan up, move the windows up/down, drain it down, see if you can kill the battery before someone comes to greet you and viola! you get a new battery under warranty.
(you didn't hear any of that from me though! lol)
Old Aug 2, 2008 | 10:46 AM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
Optima Yellow Top.
Old Aug 2, 2008 | 10:56 AM
WGO's Avatar
WGO
Originally Posted by TCKT B8
Optima Yellow Top.
Please explain why you like it.
Old Aug 2, 2008 | 11:28 AM
cclive's Avatar
cclive
Because it's the most money you can spend on a battery?
Old Aug 2, 2008 | 11:30 AM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
optima red top.
yellow top is for marine applications (deep cycle)
Old Aug 2, 2008 | 11:48 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Not necessarily . . .
Old Aug 2, 2008 | 12:27 PM
Aggie John's Avatar
Aggie John
Default Battery
Do not use Norman Frede Chev. in Houston for any type of service.
Had a dead batteryat 5:30 PM. Dealer sent flat bed tow truck.
Next day service writer calls that battery needs replacing. Gave go ahead.
Picked up car & was told they couldn't tell it was original battery. I had removed yellow sticker. Paid bill and returned next day with sticker.
Still getting run around because they say there is no way to verify this came off my Vette battery.
Any suggestion on what to do next?
IMO stay away from Norman Frede Chev. in Houston, TX.
Old Aug 2, 2008 | 12:34 PM
jabez's Avatar
jabez
when mine conked out I just threw in a Sears Platinium. Told me it was good for 5 years- guarenteed.
Old Aug 2, 2008 | 07:06 PM
  #33
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Old Aug 4, 2008 | 08:54 PM
  #34
66dreams's Avatar
66dreams
I got the best battery of all. The free one under warranty from GM!
I assumed the battery was a wear and tear item after this much time or at least they were pro-rate the cost but it was fully covered. Got some new diff additive and a wash job too.
Thanks for the advice.
Old Aug 4, 2008 | 09:54 PM
  #35
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Ok, I give up. Don't try to save any money..get absolutely the most expensive battery you can find, because if its more expensive then it must be better.
Or go to Costco and get a perfectly good one for $ 49.95.
Bought last battery for C5 at Walmart and was still going strong when I sold the car.
Old Aug 5, 2008 | 12:07 AM
  #36
Mike's Sweet 19's Avatar
Mike's Sweet 19
Originally Posted by 66dreams
Guys and Gals my battery seems to be getting weak. My C6 is almost 3 years old with about 34000 miles. Still loving it!
Any suggestions on where to go in the Houston/Cypress TX area. The dealer? Any battery shop?
Will removing /replacing the battery require resetting any onboard systems? I have the 2LT. No seat memory etc.
Thanks!
I recently replaced my AC Delco battery in my 2005 vert with a type 86 battery from Advantage Auto Parts for $100 out the door. I choose this battery after much research because it had larger CCW and surge power rating than the other type 86 batteries. It also has a great warrenty. Good luck
Old Aug 5, 2008 | 12:09 AM
  #37
4thC4at60's Avatar
4thC4at60
Originally Posted by ORANGEC6VERT
If you are still inside your 3/36 Bumper to Bumper warranty, why not see a dealer and let GM pay??
Old Aug 5, 2008 | 12:15 AM
  #38
KSCRUDE's Avatar
KSCRUDE
Been starting mine at 100 to 107 degrees for a week and heat is worse on a battery then the cold.
Old Aug 5, 2008 | 12:31 AM
  #39
johnhayesjr's Avatar
johnhayesjr
I went with a kinetix battery. way over kill for a stock vette with stock accessories but it will always give you a strong start if yopu have high commpression. 1800 cranking amps are just cool to have. nice side mount sealed battery. you can run dead and always get a full recharge. (never tried) dont want to take a chance. cost a bit more but worth it esapecially if you have extra accessories. I have 3 in my h1 now thats 5400 cranking amps. i can power a small town.
