Changing the battery should not erase any of your settings. A lot of people go for the Optima battery because it is a gel battery and does not tend to leak.
I just replaced my original, factory battery after 3+ years of problem free service. I just used a conventional battery and not an Optima.
I know Optima batteries are popular here on the forum and I'm sure they make an excellent battery. Surprisingly, both a mechanic I know and trust and the guys at the auto parts store (where they sell Optima batteries) didn't feel the Optima battery was worth the extra cost. They didn't feel the Optima would provide any better service than a conventional battery. I wasn't trying to save a few dollars I just figured I got great service from my conventional battery...there was no need to change.
Ok, I give up. Don't try to save any money..get absolutely the most expensive battery you can find, because if its more expensive then it must be better.
Or go to Costco and get a perfectly good one for $ 49.95.
I agree with most of what you said, except that I did have to re-index my windows.
Maybe you changed yours out faster than I did and your windows stayed indexed.
These batteries tend to lose their juice around 3 years, but since I've had zero issues with the Delco in my C6 I will more than likely replace it with a Delco.
Our experience with Optima's in boats was negative. Most did not last as long as a good Sears battery. My 05 is one month short of 4 years . I intend to go with a Sears Platinum (not cheap, they now go for close to $200) when the time comes.
Coming up on 4 years with Delco, no problems. Will replace with either Delco or Interstate when time comes.
I bought a new battery at O'Reilly's Auto Parts last Fall. I checked Autozone, Advance, Sears, Sam's Club and Costco, and although they had the correct "Series" battery, they didn't have the same CCA as the OE Delco (they may have one now). The battery at O'Reilly's not only had enough CCA, it had a better warranty than the Optima. Retail, it was about $85.00. They gave me a military discount and it was only $70.00. Great deal.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
CCA (Cold Cranking Amperes) tends to get over-sold. Remember back a few years (OK a few decades) when the recommendation was that the CCA should be equal to or greater than the cubic inch displacement of the engine?
To get more CCA, you need more plate AREA in the battery, so that means more plates, hence thinner plates, which ends up inducing less durability and less resistance to shorting through the plate separator envelopes. Maybe this is why the high CCA OEM Delco's only last about three years.
And CCA is measured at 0 degrees F, now I'd love to know how many here have ever started their Vettes when the battery and engine are at 0 degrees F.
Hmmmm. For what it's worth....I had an Interstate battery EXPLODE when I hit the starter a few years back. The result was really ugly. That particular brand is totally off of my list.
