Car Dusters
Old Aug 4, 2008 | 04:02 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
i use it every day followed by a some Quick Detailer.
Old Aug 4, 2008 | 04:06 PM
rjf965's Avatar
rjf965
Originally Posted by carnut08
I use one. I've used one for years on several black cars.
Here's the secret to success:
  • Make sure the car starts out clean and has a good wax job.
  • Wash your car frequently and only use the duster to remove small accumulations of dust between washings
  • Dust only when the paint is not hot to the touch, or else the wax on the duster will smear onto the paint.
  • Dust like you hate to touch the finish. Just let the duster glide ever so lightly across the finish, as if it were the weight of a feather.
  • Don't allow yourself to bear down on stuborn dirty areas or you will scratch for sure.
  • Shake excess dust from the duster before returning it to its holder
The benefits of proper use will be immediately obvious. A clean car with an otherwise unsightly fine layer of dust can be made to look nice and clean.
You can't expect to just dust continually over time and have the car continue to look clean though. The reason is road film will begin to build up on the paint and it will tend to catch and hold dust. You'll recognize the symptoms in direct sunlight because the road scum buildup will cause the finish to look dull. You'll also have to resist the temptation to bear down on the duster or 'scrub' with it. That will lead to scratching.
Follow these suggestions and you'll save yourself tons of time, have a beautiful car whenever you want to, and you won't damage your finish.
I also Vote this the best response on this never ending, bi-weekly topic.
Old Aug 4, 2008 | 04:35 PM
TA2'S-VETTE's Avatar
TA2'S-VETTE
I have used it for years. No problems. I hardly ever have to wash my vette. I keep it waxed and dust it off every other day. Then, but not everytime I dust it, i go over it with a wet microfiber cloth. The key IMO is to keep a good coat of wax on your car. It would be hard for me to do wothout my duster.
Old Aug 4, 2008 | 04:37 PM
2009 C6's Avatar
2009 C6
Good info.
Old Aug 4, 2008 | 04:38 PM
cylon's Avatar
cylon
Originally Posted by SinisterC6
mine leaves wax residue, dont know how to fix
It does that when new, use it more, and maybe on other cars of yours etc. Once the the "open" waxed threads pick up a little dust the thing works great.
Old Aug 4, 2008 | 04:45 PM
gjr2005's Avatar
gjr2005
Originally Posted by INTRUBL
It does leave a little wax residue.
Old Aug 4, 2008 | 05:45 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Have you read the instructions that came with the duster?
Tom
Old Aug 4, 2008 | 06:01 PM
budgreen3564's Avatar
budgreen3564
Originally Posted by Pocket Aces
I wouldn't use the duster on a black car. Any particles being dragged across a black paint job will end up causing visible swirls/microscratching when the sun hits it.
In IMO "If used correctly" means if not used at all.
it's perfectly safe on black cars. i've had two with no issues.
Old Aug 4, 2008 | 06:03 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
I use one and works will.
Must shake off grit.
Old Aug 4, 2008 | 06:41 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Originally Posted by sabooher
Not sure if it scratches the paint, but I'm not about to find out on my black car.
shouldnt comment if you haven used it disagree I use the California duster on my tripple black 66 big/block & Black 07 Convertable..............works great , gets the job done no scratches.............. The Dog
