Flashing Display
Old Aug 7, 2008 | 08:35 AM
Tux's Avatar
Tux
1st Gear
Default Flashing Display
The digital display on the climate control system starts flashing after about 6 miles of driving. Turning the car on and off does not reset the display. However, the next day the scenario repeats itself. Could not find anything in the manual. What does it mean?
Old Aug 7, 2008 | 09:03 AM
ALD_Z06's Avatar
ALD_Z06
Sounds like a trip to the service department is in order.
Hope it's nothing serious.
Old Aug 7, 2008 | 09:10 AM
Road Rage's Avatar
Road Rage
When this same thing happened on my Honda it was a bad relay.
Years later the same thing happened on my toyota, it was a bad relay.
I'm guessing it's a bad relay. If you have a way to check for codes you might pin it down exactly.
Old Aug 7, 2008 | 11:30 AM
nomo50's Avatar
nomo50
Do a search on the forum for "flashing"
I posted this a couple of weeks ago.
Yeaterday the dealer replaced the AC head unit. My flashing problem happened on 3 occasions, then the other day, the AC would not come on at all. I took it to the dealer, they found a code of B1000, which doesn't tell them much, but they swapped out the AC head unit anyway.
Hope this helps.
Rob.
To Flashing Display
