High Speed Wobble
Old Aug 8, 2008 | 12:30 AM
boheem's Avatar
boheem
6th Gear
Default High Speed Wobble
Hello all! Just bought my dream car, an 08 Jetstream Blue Vette on Friday. On Monday I took it right back due to a wobble that is noticable at 55 and gets almost undrivable at 90. Dealer balanced and roadforced the front 2 tires. This did nothing. THen took it back and they said the right front tire was bad and replaced it. Nothing. Wobble is the same. Any of you guys have any advice for me? I am horrrified I have made the worst decision of my life. Last time I had a wobble on a car I had to trade it in as they never figured it out. I am taking it back in tomorrow morning.
Old Aug 8, 2008 | 12:37 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
A wheel could be out-of-round. I would think that would be picked up on the Roadforce but it's worth asking about.
Old Aug 8, 2008 | 12:39 AM
beachfrontvette's Avatar
beachfrontvette
Have not heard that problem before.
I think all four wheels need balancing, not just the front. May be a bent or damaged rim?
Get an experienced corvette mechanic to take a drive with you. Take it back for warranty work and do not accept the car until you take a test drive with service rep. If it cannot be fixed, sounds like they should replace the car.
good luck!
Old Aug 8, 2008 | 12:41 AM
budgreen3564's Avatar
budgreen3564
depending on how long it sat, they could be flat spotted. as above, could be out of round but so could the wheels
Old Aug 8, 2008 | 06:38 AM
ufaj26's Avatar
ufaj26
A wobble could be any number of things involving wheels and or tires. If the dealership can't find it take it to a regular tire shop and let them figure it out and then take it back to the dealership. It can be a real pain in the a**!!! Once you have it worked out you will enjoy the ride!!
Old Aug 8, 2008 | 06:50 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
All the advice suggestions above could be correct. And it could be your dealership doesn't have a road force balancer. But still, it could the wheel(s), the tires, the balancing---all 4 should be checked. As well as having a Chev tech go out with you for a drive to see/feel the vibration since it could be in a hub/brake/suspension also.
Finally, if they say all the wheels are fine, as are the tires and the balance, you might want to try an independent shop for at least one brand of road force balance, the Hunter line (see here for one in your area: http://www.gsp9700.com/pub/search/FindLocations.cfm)
Tell us what happens and good luck.
Old Aug 8, 2008 | 07:54 AM
Mad*Max's Avatar
Mad*Max
The tires might actually need replacing, had this happen to someone I know once. They had bought a car that was sitting on a lot for a long time.
Old Aug 8, 2008 | 07:59 AM
NYC6's Avatar
NYC6
Let me see if I have this right.You have a dangerouus wobble at speed. Dealer balances front wheels says everything ok. You bring it back still complaining about wobble. They then say front wheel damaged! Why didnt they see that after the first balance? No way in hell I would trust a dealer after that! Find another place to bring the car!
Old Aug 8, 2008 | 08:05 AM
johnhayesjr's Avatar
johnhayesjr
i had a bad tire senser.so they changed them all. I went to the dealer to change. he put it in an balanced all 4 tires without removing the wheel weights.just balanced with old wights and added more. (NEVER DO THAT) at 60 miles an hour it felt like i was on a gravel highway. I went to my speed shop I do aftermarket work with. he rebalanced after taking off all weights. on a good snap on balancer. lets just say ive been up to 190 mph with no vibrations what so ever. (except my heart racing) the car was smooth.
Old Aug 8, 2008 | 08:11 AM
NYC6's Avatar
NYC6
190?
Old Aug 8, 2008 | 08:21 AM
Migs08's Avatar
Migs08
Have a friend go with you in another car so they can observe your wheels
Old Aug 8, 2008 | 09:05 AM
BEZ06's Avatar
BEZ06
What you are experiencing is something that owners that put on after market wheels sometimes complain of, but you shouldn't have it with OE wheels.
When the car is coming down the production line they put the rotors on the lugs and hold them on with Tinnerman nuts like these:
Those nuts just simply hold the rotor on until the car later on gets brake calipers and wheels put on, which is really what holds everything together.
The OE wheels have a countersunk area for the Tinnerman nut to fit into so the wheel can fit smooth and true on the hub face.
Some after market wheels don't have the countersunk area and don't mate flush with the hub and some owners have complained of exactly the problem you're experiencing until they take off those Tinnerman nuts to allow the wheel to fit tight up against the hub.
This shouldn't happen with OE wheels, but I'd still take off the Tinnerman nuts - they could even be interfering with the OE wheel mating up flush with the hub. Those nuts are not required at all, so it might be worth removing them to make sure they're not the problem.
Good luck!
Bob
Old Aug 8, 2008 | 09:25 AM
haljensen's Avatar
haljensen
The Dealer should know enough to check all 4 wheels. A bad rear tire/wheel can cause problems with handling. If all 4 wheels/tires are really "Roadforce" balanced (I haven't seen a dealer yet that had that very expensive equipment) then the next thing to check would be alignment.
Old Aug 8, 2008 | 09:34 AM
danl72's Avatar
danl72
Old Aug 8, 2008 | 09:38 AM
C6~Missle's Avatar
C6~Missle
Did they check the run-out on the wheels?
Old Aug 8, 2008 | 10:01 AM
Wayne O's Avatar
Wayne O
CF Senior Member
BINGO!
They should also inspect all steering and suspension components. They might check tire and wheel assemblies for excessive runout. A brake rotor could be imbalanced. There are more complex things they can check for but chances are it's something simple.
Old Aug 8, 2008 | 10:12 AM
ChefMark's Avatar
ChefMark
I guess I like to know how mnay miles were on it when you picked it up from the dealer. Any thing above the normal I would check more than tires and wheels.
To High Speed Wobble
Old Aug 8, 2008 | 10:28 AM
Road Rage's Avatar
Road Rage
Might this be what the service manual calls "tire waddle"?
If so, the causes listed are:
  • A steel belt not being straight within the tire
  • Excessive lateral runout of the tire
  • Excessive lateral runout of the wheel
Old Aug 8, 2008 | 10:51 AM
DaddySS's Avatar
DaddySS
I ran into a bear of a problem like this that turned out to be water in the tires. I've also had a drive shaft do it. Bottom line they need to take the problem seriously and fix it right the first time.
Old Aug 8, 2008 | 12:38 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
Although I'd bet there's an easy fix to your problem (tire or wheel), Keep in mind that we have a lemon law in Florida. Be sure to fully document each visit. I believe 3 failed attempts to fix the problem allows you to use the lemon law to get a replacement vehicle. There are Florida lawyers that specialize (I'm not one of them). Google the lemon law info - it might help if you can't get the wobbling issue resolved.
