window problems
Old Aug 12, 2008 | 06:44 PM
USNavy08vette's Avatar
USNavy08vette
Default window problems
I have a little problem. My passenger door window continually moves up and down on its on. I usually ride with the windows down. Once I roll up the windows and shut the car off, the passenger window goes down about a half inch and then back up. It does this over and over. Sometimes as many as fifty times. What can it be making this window do this? Im thinking it may be a "indexing" problem. Please help if you have ever had this happen. Thanks.
Old Aug 12, 2008 | 06:52 PM
danl72's Avatar
danl72
Try and disconnect the battery and then reconnect it after a couple of minutes. It should reset.
Old Aug 12, 2008 | 06:55 PM
BG07Z51's Avatar
BG07Z51
8th Gear
I had this problem with my '07 on the driver's side window - I would shut the car off and close the door and then the window would go up an down for quite a while. I tried to reindex the window but it did not work - I had to take it in to the dealer and they replaced a part. My dealer had to order the part and then fix it.
To window problems
