Need help please
Old Aug 20, 2008 | 01:20 PM
Stingray55's Avatar
Stingray55
Default Need help please
My buddy's C6 battery went dead while he was laid up in the hospital.
He forgot how to get the doors open.
Thanks in advance.
Old Aug 20, 2008 | 01:24 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
1) Pull key from FOB
2) Insert key above license plate
3) Open trunk and pull door latch
Good Luck
Old Aug 20, 2008 | 01:25 PM
calemasters's Avatar
calemasters
Get key
Put key in lock cylinder above rear license plate
Turn key to open hatch/deck lid
Pull left door release cable just behind LR wheel area in the trunk or hatch
Old Aug 20, 2008 | 01:26 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Thanks in advance.
- If you have the key available, you can use it to open the trunk:
- Once you open the trunk, you can pull the door release handle located on the left side of the trunk:
- Finally, after you open the door, you can pull the hood release and charge your battery.
To Need help please
