At 20K miles I got a flat and took the Corvette in to get the tire repaired. When they took the tire off they discovered that both front tires were worn down to the steel cables on the inside of the tires. The tread on the outside of the tires still looked good. Anybody else have a Corvette that came from the factory with a bad alignment?
Had the same problem with my C5. Front end was checked a was within "specs". Keep an eye on air pressure and get that front end checked, the right guy can adjust it to stop inside tire wear. Watching my '08 C6 very closely.
Thanks for the message, something for owners to watch for....
I might be wrong, but 20K miles are alot on those tires anyway.
I think that if the wear is as described, inside of both tires, it had a "camber" problem (where wheel and tires do not ride flat to the road but are kind of at an angle), as oppossed to an alignment problem.
Can also be caused by defective suspension, improper tire inflation, or carrying too much weight in the car....
Just check your tires regularly, like every 1000 miles or so for improper wear. If it was discovered only to see the steel belts, that is way too long......
Do a search on "camber". The car has too much for tire mileage and the inside goes away fast. The stock setting is -0.45 if you want to run the twisties (more camber if you really race), then get that on all 4 wheels. If you want to keep your tires and not kill the handling for a touring car, set the camber on ALL 4 tires to -0.10 and you'll get the better mileage on the tires. Camber on our cars is for fast corners. Less camber will not really hurt you unless you want to race the car. LOWER the camber to save the tires.
When I got my car in 2006 it pulled a bit so the dealer had a free alignment done. 19K miles later both front tires (Z51 supercars) were to the cords on the inside like yours. When Goodyear put on a new set they did another alignment and found the toe-in way off, even after I did the right thing and fixed the factory alignment early. Either I hit one too many pot holes or the first alignment was bad...
Elmer
Thanks for the good info. I will have them change it because I do more touring than racing.
Mine is a Z51 as well. I just wish I would have found this out sooner and gotten another 10k out of them. Thanks.
Echoing above posts: if you buy a C6, get it alligned. I did not notice any unusual wear on my tires for the first 5K miles that I owned it; but at 10,400 miles noticed uneven wear on my front tires. Snuck up on me.
Never hit anything, one driver car, tire pressure religiously maintained. And I'm looking at having to replace my front tires very soon. Ouch.
This is an old issue which has plagued a majority of C6 owners (it seems). It seems to be mostly a problem with incorrect toe as opposed to camber. It's too bad the factory can't do a more precise alignment at assembly, but for some reason they don't. Everyone buying a new Vette should assume the alignment is incorrect and get a precision 4 wheel alignment as soon as they get the car home. Even if you have to pay for it yourself you will be money ahead in the long run.
