tps help
Old Aug 30, 2008 | 10:28 AM
firebird2002's Avatar
firebird2002
Default tps help
got in my o5 and said my front tire is low so i went to check air my gauge says 30psi the dash says 23 can i reset or do i need new sensor thx
Old Aug 30, 2008 | 10:44 AM
Eritosthenes's Avatar
Eritosthenes
Got a second gauge? If it agrees with the first, you need a new sensor. (If not, toss your first gauge.)
Old Aug 30, 2008 | 10:47 AM
haljensen's Avatar
haljensen
The TPS may be in the registered in the wrong location. Check all 4 tires with a good gauge, you'll probably find one tire low. Remember that the DIC tire pressure reading isn't instant, you need to drive the car to get a current reading.
Old Aug 30, 2008 | 11:06 AM
calemasters's Avatar
calemasters
Check the other 3 tire pressures. May need to drive car to bring pressures up to date, if you added air. Reading may not update statically. As mentioned above, you may have sensors out of position. If so, dealer has a tool to re-index sensors. The procedure takes about one (1) minute.
To tps help
