Painted engine covers
Old Sep 3, 2008 | 04:08 PM
Noel@AutoBuffs's Avatar
Noel@AutoBuffs
Former Vendor
St. Jude Donor '09
Originally Posted by Atomic Autosports
I have been custom painting for a long time and have been doing C5/C6 parts for many years and never had an issue...The prep is most important from cleaning to using plastic adhesion promoters. We have done hundreds of covers on the C6 and never had a single issue. We use the PPG process and never use a primer as a base. We have seen many smoothies covers come our way from other places in the hopes they can be repaired...you can't take short cuts and skimp on materials to have them done correcty
What he said!!!
shockwave's Avatar
shockwave
Originally Posted by Swiftrider08
Take the fuel line loose at the firewall connection. Easier to get to and uses the same tool as the end under the cover. Take it loose here again in the future if you need to remove the FRC for any reason.
Get the fuel line tool and do the job the right way. You can get a 5-piece set of the tools in plastic at Autozone for about $8 or a nice 4-piece set of aluminum ones for about $20. I have both types as they come in handy for different situations.
Got the tool set and got everything in place just fine. I used the relief valve and thought I let out all the pressure. But when I removed the hose, I still got a surprise spray. Fortunately I had rags in place to catch the residual fuel. It ended up being a lot easier then I thought. Thanks for all the tips...
Old Sep 3, 2008 | 04:16 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
prep is everything. I've never had a set of my powdercoated fuel rail covers peel or have any problems. Of course with powdercoating, you have plastic fusing itself onto the plastic covers, so its virtually impossible for it to peel off.
Old Sep 3, 2008 | 04:39 PM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
I have the GM covers (Genuine Corvette Accessory ...) in Monterey Red and have no issues after a year of being my daily driver (I like the ultra-smoothies better, but I did not know about them at the time and they are not worth replacing, again).
Old Sep 3, 2008 | 06:46 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Shoot me a PM...we can hook you up and there will never be a problem!
John@autobuffs.net
Auto Buffs LLC.
2 Kerry Ct,; Suite E
Southampton, NJ 08088
609-859-0900
www.autobuffs.net
Authorized IFORGED Dealer
Custom Painting & Airbrushing
Pinstriping
Car Audio
Mobile Electronics & Video
Remote Car Starters / Alarms
Old Sep 3, 2008 | 09:21 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Wish I bought my covers from you the other parts you painted for me are top quality. We will see what this other vendor does to correct there paint problems???
Old Sep 3, 2008 | 09:24 PM
ALVetteFan's Avatar
ALVetteFan
No problems yet.
Old Sep 3, 2008 | 11:23 PM
rwarhol's Avatar
rwarhol
adhesion promoter is very important, its a must on plastic parts.
Old Sep 4, 2008 | 12:27 AM
cclive's Avatar
cclive
This is what they call "flexative" ?
Old Sep 4, 2008 | 12:52 AM
Bob1949's Avatar
Bob1949
Cruising
My fuel rail covers did the same thing.Sent them back to vender. they repainted
them for me. Problem solved. Vender said the wrong primer or undercoat was used
the first time.
Bob1949
Old Sep 4, 2008 | 07:50 AM
Atomic Autosports's Avatar
0Atomic Autosports
Former Vendor
the first time.
Bob1949
We NEVER use primer...ever. Primer does not bond as good as base coat...
Old Sep 4, 2008 | 08:41 AM
Noel@AutoBuffs
Former Vendor
St. Jude Donor '09
the first time.
Bob1949
Primer is not to be used as an adhesion promoter, Primer is for fill only. If you don't care about the heavy grain on the covers then there is no need to prime (over plastics).
We however prime all of our covers (after proper prep)to eliminate the heavy unsightly grain, this is the only way to truly get SMOOTH glass looking covers like the one below and everything that leaves our shop.
with over 15 years of experience (BASF/PPG/DuPont certified) with plastics and paint we have never had a problem!
Old Sep 4, 2008 | 08:56 AM
  #33
FSTENUF's Avatar
FSTENUF
6th Gear
Beautiful job on your engine compartment..........just the right amount, not over done. Nice work, good luck with it.
Ed
