hatch latch issues
Old Sep 12, 2008 | 09:13 PM
Revving High's Avatar
Revving High
Default hatch latch issues
The self closing latch only works 4 out of 10 times i close the hatch. Has anyone else experienced this?
Thanks.
Old Sep 12, 2008 | 10:04 PM
rbrcs's Avatar
rbrcs
Disabled by request 27 March 2026
I have an 08 and not had any problems yet.
Old Sep 12, 2008 | 10:20 PM
wudturner's Avatar
wudturner
I have an 08. Took delivery on 10/31/07. Try opening a door before you drop the lid to see if that makes a difference. Mine would never close when new if all the doors were closed and the windows were up. Now it has loosened up and about have the time it will close and latch without gentle downward pressure
Old Sep 12, 2008 | 10:31 PM
tfkrato's Avatar
tfkrato
Never a problem with my 2008 hatch closing.
Old Sep 13, 2008 | 12:57 AM
Buffalo3's Avatar
Buffalo3
On my 08 a door or window has to be open for the hatch to latch when dropped from a few inches.
Old Sep 13, 2008 | 02:23 AM
Shortimer's Avatar
Shortimer
Same here, if a door or window isn't open just a bit I need to give the hatch a pretty good pull to get it to latch. Just goes to show how tightly these cars seal.
Old Sep 13, 2008 | 02:40 AM
calemasters's Avatar
calemasters
Thanks.
In the owner's DVD with Dave Hill, he closed the hatch until the stricker met the latch and then pushed down gently on the center of the hatch until the "pulll down" motor engaged.
Most hatches on the C6 will not automatically pull down if the side doors and windows are closed, due to the positive pressure in the cabin when the hatch closes.
Old Sep 13, 2008 | 02:50 AM
bimmerborn's Avatar
bimmerborn
I see what you are saying. Only once (out of 20 times) it did not latch automatically. This is also 08.
Old Sep 13, 2008 | 06:56 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Thanks.
I'm confused. Are you saying the motor doesn't engage at all or are you saying it doesn't engage when you just drop the hatch from a few inches with the doors and windows closed. If you push down on the latch the motor should always engage. With the car closed I can drop the hatch from where it first starts to fall on its own (over a foot) and it will still only engage the motor about half the time. This is "normal".
Old Sep 13, 2008 | 07:04 AM
bksnoopy's Avatar
bksnoopy
Thanks.
The only time I had any problems (so far) is when I try to close it with both doors closed. Too much back pressure. Works 100% if one of the doors is left open while closing the hatch.
Old Sep 13, 2008 | 07:07 AM
Mad*Max's Avatar
Mad*Max
I have an '07 and haven't had a miss yet - get your dealer to fix it.
Old Sep 13, 2008 | 07:20 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Watch the dvd "rebuilding the icon" great doc on how the C6 was developed. They have spot in when they are designing the pull down for the hatch, they cant get it to close all the time either. With the windows closed you have to "throw" it down almost
Old Sep 13, 2008 | 11:59 AM
bimmerborn's Avatar
bimmerborn
How I close my hatch is bring it down slowly, then apply a little pressure (with a napkin) so it pulls down. Try this. If did not work it might need warranty adjustment.
Old Sep 13, 2008 | 12:44 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Personally, I don't think dropping or slamming the hatch down is a good idea. I gently lower the hatch until its resting on the latching mechanism...then I use the palm/heal of my hand to press sharply down on the hatch to engage the pull-down/latching mechanism. On the rare occasion when I don't hear the pull-down mechanism engage, I repeat the procedure. In 3+ years I've never had a problem.
Old Sep 15, 2008 | 11:32 AM
Revving High
Only engages the motor once and a while.
Ill have to try leaving a window or door open to see if it engages properly. I never slam ther hatch. i let it fall on its own. Sometimes the pull down engages, sometimes it does not.
Old Sep 15, 2008 | 11:37 AM
wsharp24's Avatar
wsharp24
I have an 06 and have never had a problem.
Old Sep 15, 2008 | 11:47 AM
Pocket Aces's Avatar
Pocket Aces
I get the random pull downs also.
To hatch latch issues
Old Sep 15, 2008 | 02:22 PM
larvette's Avatar
larvette
Old Sep 15, 2008 | 02:27 PM
danl72's Avatar
danl72
Old Sep 15, 2008 | 05:23 PM
relax's Avatar
relax
Cruising
Thanks.
I have had the same problem with my 2006. Dealer ordered new switch. Not in stock yet.
