Cleaning the underside...
Old Oct 7, 2008 | 01:18 PM
Thom-ass's Avatar
Thom-ass
8th Gear
Default Cleaning the underside...
Hello,
I am getting ready to put my car away for the winter. I tried cleaning it underneath using a 1900 psi pressure washer. Somehow I was not too pleased with the end result. Iam doing this with the understanding that it will minimize corrosion.
Has anyone got any good suggestions for cleaning the underside of my car? Anything I should be careful of? Any particular products that work well? Have you done this to your car?
Maybe this endeavour will be more work than I think, as I would like to get it to look like new again (or close to). I suspect, but I could be wrong, that this may just require good old-fashioned elbow grease!
Please share your thoughts!
Regards,
Thom-***
Old Oct 7, 2008 | 01:23 PM
Shortimer's Avatar
Shortimer
Yes, lots of elbow grease for sure. A car lift is a BIG help also. There are "metal care" products on the market designed to keep all the under carriage parts looking good. You spray it on and wipe if off. A friend with a car lift did a little cleaning on my '08 coupe and I was very impressed with how easy it was to get the metal looking good. I'll give him a call and get the name of the product he used.
My friend is away in Florida. Sorry I don't have the name of the product he used on the metal.
Old Oct 7, 2008 | 01:52 PM
ohmy's Avatar
ohmy
come on, r u serious?
just hose off the salt after winter and you're fine... unless you drive in mud you don't really have to worry about the under carriage more than that, it will outlast you...
...washing the bottom of car...
Old Oct 7, 2008 | 02:07 PM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
my thoughts....I wouldn't worry about cleaning the underside....that's going way overboard....it's not going to corrode....another thought, why are you putting it away for the winter now?
Old Oct 7, 2008 | 02:20 PM
EVRGRN's Avatar
EVRGRN
Why give a guy a hard time about taking care of his car? If it seems extreme to you then just click the back button.
The guy just wants to keep the car in great shape from top to bottom and is seeking advice on products and techniques from like-minded individuals. There's nothing wrong with that.
Old Oct 7, 2008 | 02:36 PM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
he asked us to share our thoughts on top of suggestions for products...
Old Oct 7, 2008 | 02:45 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by Thom-***
Hello,
Regards,
Thom-***
Elbow grease for sure. A lift helps! I use a lot of the same stuff you would use to clean the car except I use Simple Green instead of regular car wash.
Old Oct 7, 2008 | 02:46 PM
ohmy's Avatar
ohmy
nobody is giving him a hard time, he asked for thoughts... and even if he didn't, a "post" on a forum opens the door for feedback... thats just what a forum is...
but, if you're overly sensitive to anything that isn't 100% positive, maybe public forums aren't for you?
Old Oct 7, 2008 | 03:03 PM
EVRGRN's Avatar
EVRGRN
There was nothing "sensitive" about my response. I'm merely suggesting that no one should at a guy asking for advice.
Old Oct 7, 2008 | 03:15 PM
ohmy's Avatar
ohmy
I disagree... the "giving a hard time" comment and the two suggestions you gave thus far about how people should comment (everyone should be "nice") on a forum seem very sensitive to me... but OK, if you don't see it then there is no point in discussing it further...
my apologies to the OP for slightly hijacking the thread...
One more thought on the undercarriage... I would be cautious with the chemical cleaners someone suggested earlier, it might make your metal parts look clean but I would suspect theyre not good for the painted parts, if you go with this option make sure it's OK on painted surfaces...
Old Oct 7, 2008 | 06:47 PM
cmonkey713's Avatar
cmonkey713
If you are going to take the time to clean the undercarriage, get some automotive cleaner, I use simple green and Megs Quick Detailer. I will take several hours depending on how far you want to go with the cleaning. Not hard just time consuming, I would recommend wearing safety glasses for cleaner overspray or drift while under the car. Just be carefull and support the car correctly using jack stands for saftey.
Old Oct 7, 2008 | 06:53 PM
CQRT's Avatar
CQRT
I put my car on jack stands, pop off the wheels and wash out the wheel wells once or twice a year using simple green and water . . .then usually use one of the tire foam products just to coat everything and a light tough with some fine steel wool on the aluminum brightwork.
While it's up in the air, I'll usually use a wash rag with the simple green just to wipe off the underside as well as I can reach - - also a great time to reall clean the barrells of the wheels and touch up the hubs and calipers.
It's a bit OCD . . .but whatever makes you happy . you know?
Old Oct 7, 2008 | 06:59 PM
patton's Avatar
patton
St. Jude Donor '09
Old Oct 7, 2008 | 07:17 PM
Wayne88's Avatar
Wayne88
I try keep the bottom of my Corvettes clean.
Old Oct 7, 2008 | 07:23 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
If that is what floats your car, have at it. But the suggestions re caution in using chemicals is a good one. Some react with grease, grease that you want to keep on key parts. Some react with paint, or whatever other metals are on the bottom side.
As to the psi of that blaster, I'd be careful as I'm sure you are. But I wouldn't use something with that much power. This isn't like you can see, control and back off if needed quickly like a deck, walkway or driveway. A hose, a brush (es), cleaners, etc. and that should do it.
Old Oct 7, 2008 | 07:29 PM
z51vett's Avatar
z51vett
HI Bill and I thought I was **** cleaning my car and not driving in the rain unless it was unavoidable.
How are you been busy of late.
Doug
z51vett
Old Oct 7, 2008 | 08:54 PM
St.Char's Avatar
St.Char
For those of you who have never cleaned the under-carriage of the car, "You'll be surprised with the increase in performance"
Actually, I've cleaned under my car from day one. I only do this in the Summer and Fall, before winter storage. I use vinegar and water to wipe most of it down and then tire dressing on all parts that are black, painted or otherwise.
I know that this may sound a little but, it's just part of the car enthusiast in me.
To Cleaning the underside...
Old Oct 7, 2008 | 09:06 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Some of the touch-less car washes have a mode that sprays water from underneath as you enter. Down here those type of washes are usually located at service stations.
Old Oct 7, 2008 | 09:12 PM
mksz51's Avatar
mksz51
I know this isn't exactly what you are looking for but one of the best ways to keep it clean underneath (and I do value that also; I know exactly what you are thinking) is preventive. The best way to prevent problems is to not drive it in inclement conditions. I don't drive in rain - this is exactly why. Some don't get that - others do. I plan to have my car and have it looking good 20+ years from now. Everything you do today WILL make a difference in appearance 20 years from now. Good luck.
Old Oct 7, 2008 | 10:51 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
