when lowering does it effect alignment
Old Oct 21, 2008 | 11:12 PM
HANNY's Avatar
HANNY
Default when lowering does it effect alignment
couldnt find the answer in the search (probably didnt look hard enuf) but does it effect camber or toe when you lower the front? which would mean it would need an alignment. thxs for the input. paul
Old Oct 22, 2008 | 12:02 AM
haljensen's Avatar
haljensen
YES. Lowering (or raising) suspension changes the alignment. Get a Professional (NOT the DEALER!) Alignment done after changing height of front or rear.
Old Oct 22, 2008 | 12:17 AM
JTS97Z28's Avatar
JTS97Z28
Yeah getting an alignment is recommended however doesn't need to be done right away you just don't wanna put say 10,000 miles on it without doing it otherwise you may see some tire wear issues. I would recommend lowering the rear as well as these things comes stock with a already lower front end rake. The car would start to look funny with the front way lower than the rear. For the perfect ride height (in my opinion), I turned the front bolts all the way, and the rears all the way and removed one layer of bushing (only on rears). Plenty of ground clearance I never scrape on anything, no negative effects on ride or handling and looks VERY nice
Here is a picture of a 05 Z51 suspension with the above lowering
Old Oct 22, 2008 | 12:20 AM
HANNY's Avatar
HANNY
nice stancethxs for the input, paul
Old Oct 22, 2008 | 12:22 AM
keyplyr's Avatar
keyplyr
Old Oct 22, 2008 | 08:07 AM
jschindler's Avatar
jschindler
I've lowered four Corvettes and never had any of them aligned, and never had any problems. I have several friends who lowered and did not have them aligned either. Is it a good idea? Probably. But I honesly don't think it changes the alignment.
Old Oct 22, 2008 | 10:27 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Slammed my C5 and have not had it aligned in over 13k since the lowering and no issues at all
Old Oct 22, 2008 | 10:41 AM
Vet's Avatar
Vet
Raising will greatly effect the toe in the front. If you study the geometry, raising will throw the alignment out more than lowering, on a per degree of change basis. My 3/4" raise threw my alignment out considerably.
The front toe is effected during a raise since the tie rod ends effectively become "shorter" as the frame gets raised up (and away) with respect to the spindles. The wheels get pulled / toed in... and extra wear / feathering of the outside edge of the front tires will occur. When lowering, the opposite might occur but to a lesser extent.
Camber of course is effected in all situations.
When in doubt, align the car. It's well worth it. For all you know your alignment isn't even perfect right now. A good proper alignment can make a world of difference in feel and handling, especially with these cars. Your car might feel better than ever before.
Old Oct 22, 2008 | 10:59 AM
johnodrake's Avatar
johnodrake
Moderator
Jim is correct. Lowering does not change the alignment, which is a mechanical set. It does change the suspension dynamics though and the factory specs may not be ideal. A really good professional can take this into consideration for better handling and/or tire wear.
Old Oct 22, 2008 | 11:35 AM
ohmy's Avatar
ohmy
It WILL change the alignment, however it might be a small enough change that it will not be noticed...
Typically when you lower a car it would increase the negative camber...
this is actually often a good thing! First, it is beneficial to cornering.... Second, if your tires wear on the outside first (probably) it might actually remedy the situation and you'll actually see more even wear...
Old Oct 22, 2008 | 11:41 AM
Racer86's Avatar
Racer86
Any one measuring the settings before and after lowering will find that it has changed. Hard numbers are much better than opinions. Camber, bump steer, toe, roll centers, rake, castor, and corner weights, will all be affected. Maybe not critical for a slight lowering , but they all change. A basic study course in suspension will increase your understanding of suspension and how all the elements interact and change with each setting.
Again, maybe not critical for a slight lowering, but, Please don't tell people that nothing changes.
Old Oct 22, 2008 | 11:57 AM
User 81424's Avatar
User 81424
Sorry man, it does change the camber, makes it more negative.
Old Oct 22, 2008 | 10:55 PM
corvette dave's Avatar
corvette dave
With a camber change so goes the toe. Probably caster too.
Can't believe some are saying the alignment does not change.
Old Oct 22, 2008 | 11:25 PM
D2-AUTOSPORT's Avatar
0D2-AUTOSPORT
Former Vendor
Yes you'll need an alignment after the lowering. When you go don't let them correct the camber as a little negative camber can be great for handling.
Old Oct 22, 2008 | 11:38 PM
pokerplayer's Avatar
pokerplayer
Yes, camber and toe will change. Since its not a dramatic change it will only change the values a little bit but I would definitely get an alignment after the suspension settles down around couple of hundred miles. I lowered mine in stock bolts all four corners and planning on trimming one section of the rear bushing and will allign her again after that.
Goodluck!
Mike
Old Oct 23, 2008 | 12:01 AM
HANNY's Avatar
HANNY
i did aligments (every aspect of repairs actually) for alot of years but never did lower anything then check the alignment so all I can speak to is theory here.
In theory lowering the front would decrease camber and increase toe. If you lower the front and rear equally it will not effect caster. If you lower just the front it will decrease the caster.
The transverse leafspring vetts have is a different setup then what i have dealt with before. The lowering process is merely loosening/stiffening the pressure on the springs, hense lowering/raising ride height.
It has to decrease camber and increase toe but i doubt its very much. I would be more worried about the toe changing then the camber. A slight more negative CAMBER is a good thing for handling. but a toe out condition is not.
I will lower mine and take some before and after measurements to confirm all this. Thxs for the inputs, Paul
Old Oct 23, 2008 | 12:45 AM
haljensen's Avatar
haljensen
Those of you that lowered your cars without doing an alignment and aren't destroying tires should run out and buy as many Lottery Tickets as you can afford, the Force is with you.
To when lowering does it effect alignment
Old Oct 23, 2008 | 02:01 AM
glass slipper's Avatar
glass slipper
I agree with most of what you said (camber does change a little). All Corvettes since the mid '80s have had zero bump steer meaning toe doesn't change as the suspension goes through it's travel. So when you lower it, toe doesn't change...any suspension book will verify that. The SLA front suspension has negative camber gain on compression but it's minimal with the small amount of travel associated with lowering. But people who are likely to lower their car are also likely to drive a little more aggressively meaning the increased wear to the inside of the tire caused by the small amount of extra negative camber is countered by the extra wear on the outside of the tire caused by the more aggressive driving. But like Jim said, it's probably a good idea to get it checked. Or better yet, learn how to do it yourself in your driveway and check it as often as you like for free...that's what I do.
Old Oct 23, 2008 | 02:07 AM
glass slipper
Bump steer will not change...that's a setting governed by the geometry/length/attachment points of the suspension components which doesn't change with lowering.
Old Oct 23, 2008 | 02:13 AM
glass slipper
You've got it backwards. When you're doing an alignment and adjust camber, you do in fact change toe. But when you have a camber change due to suspension travel, you don't get toe changes with a zero bump steer suspension. Otherwise the car would be a handful in corners when hitting bumps. I can't believe some are saying toe changes.
