Rear Jack Location
Old Oct 25, 2008 | 01:11 PM
antt's Avatar
antt
Default Rear Jack Location
The owner's manual indicates the jack location and states that the jack pad must span two crossmember ribs. However, the crossmember ribs at the control arm pivot point locations are not level or even close to level. The rib on the front side of the pivot point is 5/8" higher than the rib on the back side of the pivot point.
Should I make a wooden wedge to install between the jack and the crossmember, or is one rib adequate?
Old Oct 25, 2008 | 01:15 PM
NW_Vettes's Avatar
NW_Vettes
It's not advised to use one rib but I have done it when needed. I'd suggest cutting a 2x6 or 2x8 and jack it up this way. This will allow the weight to be better distributed
The way I did it was use a 2x6 with small 2x6's cut for the ended making a u shape so weight was towards the sides while lifting in the center
Old Oct 25, 2008 | 01:23 PM
Wayne O's Avatar
Wayne O
CF Senior Member
You can use a board but I'd suggest using the Northern Tool adaptor beam with a quality floor jack. Here are some links that may help.
http://forums.corvetteforum.com/show...55&forum_id=74
Modifying Northern tool support beam for use on Craftsmen floor jack:
http://forums.corvetteforum.com/show....php?t=1329729
(This is a simple and worthwhile modification allowing the adapator beam to be fully and safely seated on the jack. If you want the images with this thread, PM me...I have them).
Link to Northern Tool adaptor beam:
http://www.northerntool.com/webapp/w...=47686&R=47686
Old Oct 25, 2008 | 01:46 PM
antt's Avatar
antt
I have a support beam similar to the northern tool beam with a Sears 2 ton aluminum jack. But when the jack is raised to contact the cross member, the pad only contacts the rib on the rear side of the control arm pivot point as the rib on the front side is 5/8" higher.
Old Oct 25, 2008 | 02:46 PM
Beezvette's Avatar
Beezvette
When I first bought the C6, I ordered the part from Northern but it was on back order. So being a woodworker, I made a part from a 4x4, with the proper angle to accommodate the diffence that you mention. Works great. BTW I also have wooden ramps to drive up on, and wooden blocks to put under the rear wheels while I am doing the actual oil change.
Old Oct 25, 2008 | 03:48 PM
cmonkey713's Avatar
cmonkey713
Could someone post a pictue of the wood adapters?
Old Oct 25, 2008 | 03:58 PM
goatts's Avatar
goatts
Click on the Jack link on Bugman's site:
http://www.bugmanweb.com/c6/c6index.html
Old Oct 25, 2008 | 04:01 PM
STEVE MC's Avatar
STEVE MC
Wayne is right, the Northern Tool cross beam adapter is the way to go.
Modifying it to your jack can be a project though. Luckily I have a tool room at my disposale.
I had to fit mine to my Omega low profile jack and I have to tell ya it works great. I attached some rubber pads to the center piece for when I use it on the front end since you cannot use the extension pads there.
Old Oct 25, 2008 | 05:04 PM
Dontrunmeover's Avatar
Dontrunmeover
good info. Need to get one of those crossbeam adapters
To Rear Jack Location
