Talon90 might chime in with a figure. If I remember what he told my Corvette group recently it's around 27-29 days before the battery needs some attention after just sitting without a charger in place.
My car sat untouched and without a charger of any kind for a little over 3 weeks (24 days). When I got in to start it again, it fired up immediately as if I had just driven it the day before. No issues whatsoever.
(2006 coupe with a manual transmission)
Some good luck examples here. I've tried a max of 10 days....that's after my new (less than 3 mos. old) battery went dead in 26 days. After that, I bought a battery maintainer.
IIRC, BG told me not to go longer than 14 days, that my alternator would have great difficulty charging the battery, even at a sustained 1500+ rpms for 30-45 minutes (which is what they recommended). They also recommended a battery maintainer.
OK it's probably in the manual but Raazor mentioned a reading of 15.5 What is the voltage range that should be showing up?
In the winter's of Washington, I will sometimes go 3-4 weeks without driving and it starts up fine but ....I did buy a tender to keep the Vette and the T-bird battery ready for a call at any time rain or shine (no ice though...tried that once.
I'd still like to know WHY there is such a wide variance between cars on this issue! I have in fact gone a solid 6 weeks without any tender and the car fired right up. No issues at all while others say 2 weeks? What could be so different between cars? I have factory battery in mine so that's not why is can sit that long. It's a 3lt optioned car so everything is in it. I have my V1 hooked into the mirror so that doesn't drain anything.
Anyone have any ideas why some cars can sit for 30 and 40 days while others are dead in 2 weeks of less?
I'd say somewhere around 3-4 weeks last winter. The car sat in the garage for atleast a solid 3 weeks, maybe 4 before the roads were dry enough to drive it.
One guess is that OnStar may have some impact on battery life.
