Trunk release button failure
Old Nov 29, 2008 | 12:05 PM
danl72's Avatar
danl72
Originally Posted by Shortimer
Good to know it's a DIY fix. Thanks for the info.
Old Nov 29, 2008 | 12:54 PM
LMB-Z's Avatar
LMB-Z
Just did mine a week ago. The switch has a clip on one side that needs to be pulled up in order to allow it to release. Its hard to find just by feeling. One side of the switch is flat, the other has the clip on it. To re-install, just push it back in and it will lock in place. Hope this helps.
Old Nov 29, 2008 | 01:44 PM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
That helped a lot, thank you! With your good description I was able to easily release the clip and get the wire off. Once you do that how do you get the switch out? I know it must be simple but for some reason I can't seem to get it. Thanks again!
Old Nov 29, 2008 | 03:35 PM
LMB-Z's Avatar
LMB-Z
pm sent
Old Nov 29, 2008 | 04:18 PM
johnhayesjr's Avatar
johnhayesjr
WOW. Never knew I had a switch there. I just walked down and check if i did. And holy cow I have one two. Great GM sales demo I got. BTW mine works fine. LOL
Old Nov 30, 2008 | 07:30 PM
C6 MoneyPit
Default Well that was easy...
A big thank you to firecop90conv for giving me the info on removing the switch. I was making it difficult when it is so simple when you know how. As he told me, after you remove the wire clip, feel around the bottom of the swich and there are little springs. Push them in as you push the switch down toward the license plate. It popped right out easy as pie! Thanks again firecop90conv for the assist!
Old Dec 1, 2008 | 08:07 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by spinalator
My switch works, but the trunk does not fully open. I have to press the switch and at the same time shove my fingers under the trunk lid and pry it up. Total pain in the ***.
I don't think it is supposed to fully open- only unlatch.
Old Feb 28, 2009 | 06:00 PM
mcc978's Avatar
mcc978
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17,’18,’19
Originally Posted by jwswanson
Mine failed and I had it replaced under warranty so I don't know the cost. From the paperwork, it lists "N2388 Switch - Rear Compartment - Lid Release, Part number: 15259992 Switch.
Hope this helps.
John
Mine just failed today. How long did it take the dealer to fix yours? I would try it myself but since it is still under warranty and there seems to be a chance of dropping something, I don't want to mess anything up.
Old Feb 28, 2009 | 07:18 PM
orca1946's Avatar
orca1946
I never knew? I'll have to go look.
Old Feb 28, 2009 | 07:29 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
It's a pain in the A problem cheep switch which I have replaced twice in one year.
