Nitto Invo's
Couldn't resist. I guess this means you officially are keeping the Corvette.
Those GY Run Flats really are crap NEVER again.
http://forums.corvetteforum.com/c6-c...r-hate-em.html
Reading>You
Again Mine 19th>Yours 20th
Sometimes the search button is good Mmmmkay?
Steering Response and Traction
•Silica-reinforced tread compound reduces tread flex for excellent road biting traction.
•Tread blocks on the outer shoulder provides maximum contact patch for maximum dry traction and responsive steering feedback.
•Continuous inner shoulder tread and sipes provide improved traction under dry or wet conditions.
•Slanted 3D tread blocks reduce flex for improved cornering performance.
•Twin water-dispersion grooves effectively increases contact patch in the wet.
Ride Comfort
•Variable pitch blocks are utilized to reduce road noise.
•Pattern allows for tire rotation on staggered fitments, resulting in a quiet and comfortable ride."
The tread design was inspired by Yokohama (they assisted Nitto behind the scene). good tire. treadwear will be marginal though... but hey, who cares?
Michael
I have had Nitto Invo's (the same set even) on my C6 now for about 17,000 miles and have nothing bad to say about them.
I'm running a 255 front and 305 rear setup on the car, and have probably 50-60% life on the fronts and 30-40% life on the rears left. Compared to the 14,000 miles I could stretch out of a set of the SuperCar's.
Quite ride, grip good, work better than the GY's in the rain. I'm happy with them as a spirited daily driver.
BTW Anthony, what wheel's/sizes are those?
