Need some help. Received one of my new mods today (FRC) and to my surprise the directions state that I need to remove the fuel line to get my stock ones off and put on the new ones. Is this necessary? I'm no mechanic when it comes to this level of "do-it-yourself" mods. Any words of encouragement or maybe another way of installing?
I'd say, wrap the fuel line with painters tape, and carefully wiggle it past/thru the FRC. Do the same with the new one.
If your new ones are painted, I think the mfr/vendor is just taking the extra precaution that you WON'T be careful and will damage the paint. Then you'll want to return it and blame the vendor. So, if you want to do it with zero chance of damage, remove the fuel line.
You can put blue painters tape on the FRC and the fuel line to prevent scratching. I did it on my 05 C6 and it worked fine. On my Z06, I did pull the fuel line. It was very very easy to do. I bought the tool for about $5.00. I am in the airport right now, but if someone doesn't respond with the tool name and part #, PM me and I will get that info to you tomorrow.
Appreciate both your inputs. I'll try the blue painters tape first and see if I can do it "carefully"!! If not - I'll send you message for the tool information. Thanks again!!
After removing my FRCs several times I found it is easiest to just wrap a detailing towel around the fuel line. Also make sure the covers are warm to make them more pliable.
I've removed mine many times and here is the best way.
1) Blue painters tape around fuel line.
2) Heat cover up in that area with blow dryer. Get it nice and warm. It will be so flexible that you won't even touch the fuel line putting it on(still do the tape for though)
To take them off, just drive for awhile. That will heat them up and make it easy.
I tried taking the one off on the side of the fuel line and could't do it. Like you mentioned - I'm going to have to warm it up first -- it is about 42 degrees in my garage right now. Will let you know if it all works out
You've gotten some good advice and no question removing the fuel line is your best bet. Another good suggestion is to take driver's side cover...tape the edges with painters tape and then wrap it in a large bath towel. Start and run your clothes dryer for a good while to build-up heat...shut-off the dryer and place your towel-wrapped coil cover in the dryer (but DON'T START THE DRYER). Just let it heat up and it will become more pliable.
Also, use your old coil cover and practice installing it before you try installing your new cover. If you bend it too far it's better to find out on your old cover. It's not difficult to do...practice first.
I used tape on the edges of the opening in the FRC and on the fuel line. I also used some vasoline on the edges over the tape. It was a warm day and they went on with little effort and no damage to the paint on the FRC.
Great suggestions!! I finally got the stock cover off - over the fuel line. I used a heat gun to warm it up. It was still a bear to get off. Unfortunately I couldn't find any painters tape so I have to wait until tomorrow to hit Lowes/Home Depot for that. I will practice with the stock cover first. Thanks again for all your help/suggestions. A great forum indeed!!
This issue seems to come up periodically and I am always surprised to see how many experienced Vette modders advocate heating/bending/taping the covers to install them.
You can go to AutoZone, O'Reilley's, or any other automotive store and buy a simple plastic tool that will easily remove the fuel line. Removing the fuel line, swapping out the FRC, and re-connecting the fuel line literally takes less than 2 minutes using this procedure. Why risk scratching or breaking your new cover (or taking the time to do all this prep work)?
I recommend having a rag handy to catch any fuel drops that may drip when you disconnect the fuel line and I wouldn't recommend disconnecting the fuel line while the engine is hot.
Too late...cut myself already!! I do have one question though...when removing the fuel line, do I need to bleed the line? Anything special other than to get a cheap $5 tool from Autozone and unhook it? Sounds way too easy. If you guys were in Dayton, I would take you up on it and the beer is on me!!
Another possible suggestion: Get a clear soft plastic hose about the size of the fuel line, cut to length and slit it so it can be put on the fuel line, put a little vaseline on the plastic hose and slide on the FRC. Similar to using the painters tape idea.
No need to bleed the line, but I've always done this with a cold engine to ensure no pressure exists in the line - not sure if this step is necessary but seems like a prudent precaution. Only a few drips of fuel will come out when you disconnect the line - easily caught in a rag.
You're right - this is too easy which is why I don't understand why everyone doesn't use this method.
I'm getting ready for this mod too, so thanks in advance for all the good advice.
Question: How are the FRCs attached to the engine? Is it hard to remove and replace the new ones? They can't be loose, but I imagine that they "snap" into place or something.
I received my painted FRCs yesterday. I went to Checkers Auto and rented the fuel line removal tool. Some fuel did SHOOT out and got all over. Anyway, it was not that big of a deal, but for sure, a pain in the neck.
...just my $0.02
Good Luck!
Pull the fuel line off at the firewall to avoid splash fuel on the new FRC when putting it back. There is a samll amount of fuel in the line so have a rag handy. The plastic fuel line tool works just fine. We used a $10.00 aluminum tool kit from AutoZone but the $5.00 tool does the same thing.
they push on to some posts, very easily. trust try loosening the passenger side one by gently lifting it up along one edge. gentle is the operative word.
