Balancer Mishap
Old Nov 21, 2008 | 07:16 PM
Deceptikon's Avatar
Deceptikon
Default Balancer Mishap
I have a 2005 C6 w/ 60K on it. A week ago the engine started to make a sickening grinding at 35 - 40 mph. I shut the car down and saw that there was red fluid spewing from the front of the crank case. Apparently the bolt that holds the balancer in place ran itself out and the balancer became totaly detached from the crank. GM says $6k to rebuild. Lucky I have a CPO and it is covered. WARNING: Check that bolt
Old Nov 21, 2008 | 07:24 PM
VET4LES's Avatar
VET4LES
If you have an early 05 there is a TSB on this issue. Do a search and you find many post about it.
Old Nov 21, 2008 | 07:55 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
That's bad. Question: what is a CPO?
Old Nov 21, 2008 | 08:19 PM
Walt White Coupe's Avatar
Walt White Coupe
Don't know what a CPO is but repair should be covered under an outstanding TSB if the car is in the first 11,039 05's built. Last 5 digits of vin is your number. See attachment.
File Type: doc
Old Nov 21, 2008 | 08:55 PM
Scott03Z06's Avatar
Scott03Z06
Certified Pre-Owned???
Old Nov 21, 2008 | 11:20 PM
Vietnam Vette's Avatar
Vietnam Vette
Ouch!
Old Nov 22, 2008 | 08:54 AM
moolys's Avatar
moolys
St. Jude Donor '09
that sucks big time
Old Nov 22, 2008 | 10:30 AM
Wayne O's Avatar
Wayne O
CF Senior Member
A TSB is not a recall...repairs are not automatically covered just because a TSB was issued about the potential problem. A valid OEM or extended warranty should cover the repairs otherwise the repair's on you.
Old Nov 23, 2008 | 08:58 PM
Deceptikon's Avatar
Deceptikon
certified pre owned. A CPO car comes with the balance of the remaining 100k mile drive train warranty
Old Nov 23, 2008 | 09:00 PM
cclive's Avatar
cclive
That was smart!
Old Nov 23, 2008 | 09:05 PM
Deceptikon's Avatar
Deceptikon
Thanks for the info. I have anohther issue that I have mentioned in the posting regarding warranties.
Old Nov 23, 2008 | 09:21 PM
calemasters's Avatar
calemasters
A Technical Service Bulletin is not a recall, and does not extend the warranty. If the vehicle is stock, I would hope the dealer would provide some goodwill.
Old Nov 23, 2008 | 09:22 PM
VET4LES's Avatar
VET4LES
Is this the GMPP warranty? 2005 came with 3 year or 36,000 mile warranty.
Old Nov 24, 2008 | 11:23 PM
Deceptikon's Avatar
Deceptikon
Not GMPP, the dealer used another set of letters. Not too sure what the exact name is. Van Chev in Scottsdale is covering the cost of the repair.
To Balancer Mishap
