From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
What's with all this "low tank/sucking off the bottom"? Why would any system have a floating suction pipe? As Bob pointed out, the suction is taken a few inches off the bottom. It doesn't matter if the tank is empty or full, any gas that comes out of the nozzle came from a few inches above the bottom of the tank.
And the reason Top Tier is important in this case is they tend to be the better operated stations. A station that is pumping gas 3 cents cheaper than a Top Tier station has to recover that 3 cents somewhere. One easy place is not changing filters as often.
I dont see how all eight fuel injector had to be cleaned. If the gas had water I think changing fuel filter and draining tank is all you had to do. You said the car still ran but bucked. To clog a fuel injector (8 of them) you had to have large particles of say a glue like substance get past the fuel filter and into the fuel rails than the injectors. I think your mechanic got you on this one. I high pressure injector takes years to build up enough crap to start clogging. It is usually shellac from gas drips sitting to long. I'M not doubting your mechanic did the work I think he did a lot of unnecessary work. i wish he took a picture op the injector for you to see. It was probably cleaned for nothing. You got me on the 02 sensors. Unless the car was really detonating I think that was an unnecessary change. Did you service engine like come on and did you get the codes. If the 02s are bad the car tells you. Throttle body well no fuel there. But it probably looks pretty when you wipe it with a rag. What was that charge to clean that?
Service engine light was on, codes P0171 and P0300. Report said engine misfire on cyl 11 3 5 7.
Is it possible the gas had a high content of ethanol? My Service Manager son has seen this problem a few times. The ethanol content was in the 18-20% range and the cars would hardly run.
In most areas ethanol is splash blended in the tanker after it is filled with gas and then blends as the truck goes down the highway....
Valero is the second (maybe first) largest refiner in the U.S. and only recently started selling gas under their name. It is a quality product. Ethanol is blended in almost all the gas sold in the U.S. up to 10% per gallon. Next year, under federal mandate ALL gas in the U.S. will be required to have 10.23% ethanol. Might not seem much of a difference, but current auto makers state that there engines/systems can handle up to 10% blend (unless engine is specifically made for E-85 use). Don't know if that's going to cause problems in 2009.
Thanks. And what about the O2 sensors? What's their relationship to bad gas and the need for replacement?
It is possible for certain kinds of contaminants to poison the O2 sensors. Water won't, excess ethanol won't, ordinary dirt won't, but things like certain sulfur compounds, and of course tetra-ethyl lead, will. I doubt the O2 sensors would be harmed by the ordinary sorts of contaminants commonly found in gas station fuel.
For what it's worth, I recommend the Top Tier gasolines. I use them in all my vehicles and never a problem. Although a large refinery & producer of gasoline, Valero isn't on the list. Just my opinion.
However if your friend had Ethanol in the gas he wouldnt have water in the tank.
Here is a Diagram of a common tank. #5 show's the pump piping does not go to the bottom of the tank. Typical application is 2-3 inches off the bottom - about 400 gallons remain when the station is "out"
What the Diagram does not show are the .10 Micron filtration units on the pump itself, in addition it does not show the Electronic monitoring system data which covers water and other vital stats such as ground intrusion.
A. Tank Bottom Deflector Plates
B. Primary Tank Fittings
Ooohh I like this answer. Did the Gas have Ethanol in it ?
In some cases fuel is blended with Ethanol right at the truck. There are calculations done based on amount of fuel in the truck.
A typical gas truck has 5 Compartments with the front and rear compartment being around 2500 gallons each. the middle 3 average 3500 (1500, 1000, 1000) = 8500 gallons total.
Each compartment must have the proper amount of Ethanol dispensed into it. If the process fails it is quite possible to raise Ethanol to 20-25% which will cause conditions like the OP has described.
Thursday night on our way home from dinner I stopped and filled up with gas. I always use 93 octane gas and have been buying at this station for over 5 years. On Friday morning when I started my vette it was coughing and sputtering somthing fierce. I drove to work anyway and took it to the dealership at 8:00 am. About a hour later the service tech called me and told me that the gas was contaminated.
Well after draining the tanks, cleaning the fuel lines, injectors, throttle body and replacing the o2 sensors it cost $1057.
I contacted the Valero company and they sent me the "Customer Fuel Concern" forms. Hopefully I will get rembursed for this mess. I did save a sample of the bad gas just in case they need it.
I had the same type of bad gas problem with my '05. Filled with 93 octane and a leading dealer, name starts with "M". My Chevy dealer found deisel fuel in tank, gas station does not carry deisel. Mistake I made was fueling at station while tanker was unloading, tanker had "some" left over deisel. Tanker company would not pay, "M" paid half my $950.00 bill. BY the way, I broke a valve sping on way to dealership, no piston damage, valve did not drop down.
You would be suprised how many times a tanker used to transport diesel is then used to transport gas. It sounds like your problem was more severe then residual and I'm sorry to hear you got stuck with a bill.
Do you think they "wash" the inside of it prior to filling up with gas?
In fairness - some companies use a designated Diesel trailer. All bet's are off when Demand spikes and that trailer is on the road.
I will add that to the list of crazy reasons for top tier.... It is a long list....
Top Tier is a marketing program. All gas must contain additives. True, the name brands often have more, but even the minimum should not cause a problem. On the list Exxon/Mobil is not listed. I almost always fill all my cars (9) with Mobil and never ran into any type of problem. I guess Exxon/Mobil didn't want to shell out money to be listed with Top Tier (You can bet it cost all of them money to be listed)
Sorry to hear about that. Hopefully you will get your money back. I only use Chevron in my C6, and I used it in my C5. My C6 runs the best with Chevron.
That theory works as long as the tank does not have a leak and has been infiltrated with ground water.
The piping ensure that water from condensation does not get sucked up but a leak in an area with a high water table can fill the whole tank with water....How?
Let's say the water table is 1 foot below the surface. The tank starts full of gas. The first car pumps 20 gallons, as it flows out, 20 gallons of water flows in to replace it via the site of the leak.... The process continues and each time the gas/water mixture is pumped out, more water enters to contaminate the fuel even more...
the system uses filters in the dispensers much like aviation fuelers which swell when contacted by water and severely restricts flow of fuel through the dispenser. the unfortunate reality is that the system only works as well as the operator of the station allows it to - they can bypass the high water alarms, disconnect leak sensors and fail to change filters as needed. state regulators do not ckeck equipment as often as you think and a poor dealer or distributor can do a lot of "bad" things. add to it the transport driver errors and
