1
C5 was automatic and with the C6 I have to hit the button.
Not a big deal, but, I can't even start the car until the seat is in position. My legs are to short
There is a TSB that describes this condition as many people were taking their vehicle in for repair thinking the memory seat function was not working when, in fact, it is working correctly.
Upshot: manual transmission drivers must push the 1 or 2 button to recall the driving position memory. Also note that the seat won't move if the engine is started and the parking brake is not set.
Auto Memory Recall (Automatic Transmission
only): If your automatic transmission vehicle has the
memory package, you may have this option. This option
allows the driver’s seat, the telescopic steering column,
if your vehicle has this feature, and the outside rearview
mirrors to automatically move to the current driver’s set
position when the engine starts.
Press the OPTION button until AUTO MEMORY RECALL
appears on the display, then press the RESET button to
scroll through the following modes:
• YES
• NO (default)
If you choose YES, the driver’s seat, the outside
rearview mirrors and the telescopic steering column,
if your vehicle has this feature, positions are recalled
when you turn the ignition on.
If you choose NO, this option will turn off.
When the mode you want is selected, press the
OPTION button to set your choice and advance to
the next personal option.
first i enter car with fob#1, adjust my seats, side mirrors, HUD, steering wheel - all to my liking and press and hold button #1 by the door panel until it beeps. that's now set to automatically adjust everytime you enter with fob#1. note you can also chose for the seat to automatically back up to its original position, that way it's easier to exit out. read manual.
do the same procedure w/ fob#2, but instead of press and hold #1 you press and hold #2 button on door panel. i adjusted that based on my wife's liking.
one time i accidentally got my wife's fob#2 and it adjusted to hers. it was so close to the steering wheel, mirrors were off even HUD, lol. so i turned it off, asked her to get fob#1 and switched, without exiting the car and then re-started it while fob#1 is in the car, to my surprise, the settings are still fob#2. so i adjusted them but didn't save the setting. when i exit out, locked car and came in later on, started the car, then it's now set to fob#1.
But in the C6, you don't put the key in the ignition, so when are you expecting the car to move the seat up? On an automatic it does it when you push the starter. But a manual does not do it because of the fact that you need to push the clutch in - it's a fail safe.
