Balancer Failure Update
Old Dec 10, 2008 | 09:30 PM
CQRT's Avatar
CQRT
Originally Posted by NYC6
I would pay a little extra and have them do a LS3 install. It shouldnt be much more.
Would seem to be a great opportunity if you've got the scratch to do it . . .
Giddy-up !
Old Dec 10, 2008 | 09:54 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Mike's Sweet 05
Just read your response and was wondering if you knew the range of serial numbers affected by this balancer problem?
If you don't have that information can you tell me where I can get the serial number range??
Approaching 50K on my 05
Tried searching forum, nothing came up
Thanks.
Mike
Old Dec 10, 2008 | 10:05 PM
Hoonose's Avatar
Hoonose
Originally Posted by PhotoLad
Sorry you've had more problems with this :sadangel
So what part of the warranty covered this ? I know this pully was a problem for certain Vin. #'s in 05, but 3/36 warranty ?
Be smart and nice and GM has stepped up more than once to fix this after the warranty was out.
Old Dec 10, 2008 | 10:10 PM
Johnny Utah's Avatar
Johnny Utah
From: ,fl.Never, under any circumstances, take a sleeping pill and a laxative on the same night.
Is there a milage or approx, time this may happen? me 05 9600 miles
Old Dec 10, 2008 | 10:28 PM
Hoonose's Avatar
Hoonose
No, unfortunately. But most have happened relatively early.
I would never buy an early '05 (pre VIN 11039) that hasn't been properly 'dewed', or without a warranty.
Old Dec 10, 2008 | 10:37 PM
Michrider's Avatar
Michrider
Ask to see the crank. If it is all grooved up, the tech that did that lower end job is completely incompetent. Definately demand a different tech do the second repair.
With the balancer problem, seems like that would just damage the crank snout. There should be no reason the lower end fails after a crank replacement except for sloppy work. Some techs know how to do in car engine repairs correctly and some don't. They take short cuts like using air powered grinders and scotchbrite pads to buzz off gasket debris. The trouble with that is it throws debris everywhere, which ultimately winds up in the oil scoring the crank, then spinning a bearing.
Or they don't take the time to get the clearance right on the crank and rod bearings, and one of them spins.
Did the heads come off on the last repair? If so, ask if scotchbrite pads were used to grind on the head and deck surface. There will be circular grinding marks if they did. When the shortcutters break out the air grinders and scotchbrite pads, the job will usually come back in a week or two with wiped out bearings from all the debris in the engine.
That's why the service manuals all say hand tool gasket scraping only.
Old Dec 10, 2008 | 10:41 PM
Johnny Utah
my vin#9615:bang head: I guess Im due to the fact IM the 2nd owner of the car,went to local dealership for warranty issue,the so called VETTE MASTER TECH, told me 3:15 gear ratio was in my steering ratio so my confidence in this dealer isnt good, are there any warninig signs of this?
Old Dec 11, 2008 | 10:24 AM
anothercrisis's Avatar
anothercrisis
St. Jude Donor '06-'07-'08
I worried about this for a while when my 05 was new, but have since had every confidence in it. Most of the failures were early, but I think I read that the warning signs include noises (squeeking, scraping, etc) or the belt showing wear as the pulley moves. Some of the failures seemed so sudden that there probably wasn't much warning. Some of us painted a mark on the pulley and crank to check for movement....probably just gave us a false sense of security though...
I did buy the extended warrently bacause of this and the fact that it was a first year car. I have had a few of the minor issues, that were solved early in 05 but the car has been flawless ever since.
I always felt that the break in might have had something to do with the crank pulley failure, as it seemed that most failures were in the first six months with a few I remember being on the way home from the dealers!!. But with failures at 60k miles, this theory goes out the window.
Good luck
Anothercrisis
Old Dec 11, 2008 | 11:08 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Most instances of the crank-pulley 'walking' do not cause such severe damage but obviously in can happen. You're fortunate your warranty covered the damage. I never understood why GM stopped using a keyed crank but all the Gen III and Gen IV V8 engines use a press-fit damper with no keyway. This has been the case since the LS1 was introduced in 1997. I believe GM introduced a revised harmonic balancer with an integral (diamond embedded) friction washer as a production part in the 2006 LS2 and LS7 engines. I suspect this was also introduced informally as the 'fix' on the later model 2005 C6's as well.
Short of pinning the crank, if anyone is especially worried about this potential failure it might be worth replacing your early VIN 2005 crank-pulley with a 2006+ crank-pulley. Or perhaps, just replacing the special torque-to-yield bolt and making sure it's torqued down properly would help prevent a failure (these special bolts cannot be reused...they must be replaced with new one's).
Originally Posted by mksz51
I don't think it's the LS2. I think it's the mechanic.
Old Dec 11, 2008 | 11:13 AM
mksz51's Avatar
mksz51
You'd be paying a LOT extra - different short block. Usually a warranty item is "old" and "new" are the same part (unless the old part has been replaced by a new one that fits interchangeably - not the case here).
Old Dec 11, 2008 | 11:26 AM
9C1's Avatar
9C1
Not to pick nits, but the LT1 (at least those in my 1995) don't have keyways either. Big time PITA because some of the balance for the rotating assembly is in the damper, and if one doesn't keep the registration on the damper the balance is out the window.
Old Dec 11, 2008 | 02:25 PM
carpe dm's Avatar
carpe dm
You'll likely be getting a new short block. I'd ask specifically what PART(s) failed to cause this. Did they have to replace the crank the first time around because the end was screwed up? If so, I'd suspect someone made some mistakes with main or connecting rod bearings and / or torque specs.
Good luck.
Old Dec 11, 2008 | 02:38 PM
  #33
Deceptikon's Avatar
Deceptikon
They did replace the crank after the balancer worked its way off. No one will admit fault. They told me some debris got into the piston, which caused it to break, somehow. They are dropping in a new LS2.
Old Dec 11, 2008 | 02:43 PM
  #34
Deceptikon's Avatar
Deceptikon
Originally Posted by anothercrisis
I did not see your other thread, but I assume someone told you that the balancer working off the crank was is a known problem with 05's. DId it fall within the affected serial numbers?...I am surprised it made it to 60k miles, but at the same time I am worried as I have an 05 in the affected range too!
Good Luck
I saw the technical service bullitin and mine was in the affected range. I saw the bullitin after the catastrophy. Just have the bolt that holds the balancer to the crank checked on your C6, it may be loose
Old Dec 11, 2008 | 02:45 PM
  #35
Deceptikon's Avatar
Deceptikon
Originally Posted by talon90
Your dealership worked on your bottom end. A part failed in the bottom end after they worked on it and trashed the top end. Your loosing faith in the LS2? I'd be loosing faith in the mechanic that worked on it and probably didn't fix it right the first time. First clue, "it's better than ever"
It may be the mechanic. I have atken steps to get another one.
Old Dec 11, 2008 | 02:47 PM
  #36
Deceptikon's Avatar
Deceptikon
Originally Posted by Eritosthenes
As mksz51 has already noted, Deceptikon is more likely to get a replacement short block than a completely new engine (as in a "crate"). I sure hate to see an owner/victim go through something like this. The GM regional manager should step in and be personally involved from the moment of the second failure.
Just out of curiosity, Deceptikon, what kind of vehicle has the Chevy dealer given you to drive while yours is out-of-service?
Van Cheverolet is giving me an Impala as a loner. I just found out they are dropping a whole new power plant (crate), not just the block.
Old Dec 11, 2008 | 02:49 PM
  #37
Deceptikon's Avatar
Deceptikon
Originally Posted by R50THC5
can you say....I want an LS7......never hurts to ask
I did ask, they will only replace what was broken, in this case an LS2.
To Balancer Failure Update
Old Dec 11, 2008 | 02:52 PM
  #38
Deceptikon's Avatar
Deceptikon
I bought the car w/ 50K on it. It is a Certified Pre Owned car. This means I have the rest of the 100K power train warranty.
Old Dec 11, 2008 | 02:54 PM
  #39
Deceptikon's Avatar
Deceptikon
I don't think you have much to worry about at 9 or 10K. But have the bolt that holds the balancer to the crank checked. Mine failed at 60k
Old Dec 11, 2008 | 03:28 PM
  #40
Hoonose's Avatar
Hoonose
'05's didn't have the 100K warranty, do the certified ones?
