Scissor jack?
This puck has a "pin" on the top that fits into the car's frame hole and a "pin" on the bottom that fits into a hydraulic jack pad hole. Get two of these pucks and two heavy-duty hydraulic floor jacks and you'll have an extremely solid set-up for raising the front, rear, or a side of the car.
Scissor jacks... you must be referring to some type of very heavy-duty ones because the ones that most of us are familair with are not nearly as heavy-duty or reliable as a good hydraulic floor jack. Plus, typically, scissor jacks have a much smaller footprint and may have a tendancy to want to "topple over" where big heavy-duty hydraulic floor jacks, especially if you use two (one on each side of the car) placed and different angles, would be nearly impossible to topple over.
In general, I'd be more concerned about the "topple over" factor using a small footprint jack than the "slip off" factor using even standard rubber-type pucks... that is assuming things are placed in a "proper" manner.
http://www.mamotorworks.com/corvette?frame=1.174
I discovered the floor stands would not work either due to interference with the air dam.
I solved the problem by making some 2 x 10 starter ramps that allow the air dam to clear before starting up the store bought ramps.
I also rigged some 2 x 4 from the ramps to the garage wall to keep the ramps from sliding foreward when I drive up.
LJ
I don't feel it is unsafe to use at all. Sometimes I use it for pulling a wheel/tire off the front, for detailing, at a show also...
Like anything...using the proper care with any jack, is a must.
http://mikemercury.home.att.net/ramp.htm
http://forums.corvetteforum.com/c6-c...ml?forum_id=74
The method in this above post is considered by most to be extreme overkill and I can understand why, but, it does appear you are concerned about achieving the greatest degree of stability when jacking the car. If you were to jack the car as described in the above linked post and then ALSO add a screw jack under each puck point, the car would be almost impossible to knock over... would be earthquake-proof. I don't think it could get any better for a mobile set-up, at least with all four wheels OFF the ground.
You could also, as you suggest, place hydraulic floor jacks under the PUCK points (as in the two front puck points for instance), from the sides of the car, and then place stands under the "preferred" points on the main front crossmember... I'd think this would also be just fine, but just make sure that the jack stands you use will properly support the aluminum ribs of the crossmember... the stands should have a wide perch and you may want to add a block of wood or something to help distribute the load across the ribs, etc... but pay attention here because if this step isn't done "right", you can have problems... a block of wood could split, etc...
I'm not a big fan of using wood in general for these types of things, a lot of folks put way too much confidence in wood and that's a big mistake in my opinion. While a 2"X4" or even 4"X4" might not snap in half so easily, it could split length-wise very easily, causing the car to shift suddenly which could lead to a collapse. I'll buy and use a steel Northern cross beam adapter any day before rolling the dice with a piece of wood. Your life is worth the price of good lifting tools.
But in sum, I have lifted my car using a hydraulic floor jack on each front puck point (with nylon pucks in place), placing the jacks at the SIDES of the car... yes, you need to walk back and forth and jack little by little from side to side... it's ok, we all need the exercise... I unfortunately do not remember what I used for support under the crossmember that time... I likely used my Blackhawk forklift stands that have nice wide flat perches with possibly small blocks of hard rubber on top... as it says in the owner's manual, you need to span across more than one aluminum rib of the crossmember when supporting.
But keep in mind, for oil changes and the like, ramps may be the easiest solution. I personally do not like ramps because often I need to raise my car in my tight garage, and with a manual tranny, I don't trust myself to ride the clutch up steep ramps only inches from the garage wall... one minor slip and I could smack the wall... so, for me, it's jacks and stands.
The manual shows the "preferred" lifting locations... lift from those locations and you should be ok.
The front and rear crossmembers are made of what appears to be cast aluminum or similar... they are designed to take the evenly spread and "shock-absorbed" stress of the suspension, not necessarily take the stress of a single jack pushing up in one small spot against the full weight of the car (or much of it anyway). Doing this places way more localized stress (pressure) on the member than it was specifically designed for.
Can you crack a crossmember jacking from the center of it with one jack??? I don't think we've ever heard any reports of this happening, so maybe not. But why tempt fate and ignore the factory instructions?
If anything, I think you could maybe get away with lifting from the center of the larger front crossmember if you place something under it to distribute the pressure (some like using a piece of 4"X4", but... wood flexes a good deal even though it doesn't appear to, and it could split, so...). Lifting from the center of the larger front crossmember IS actually considered an "optional" lifting point in the manual (though not "preferred"), so I guess it's not too much of a sin to lift from there... but they do not go into much detail beyond that.
But jacking in the center of the smaller front crossmember (which is easier to access)... I would very much NOT recommend that... I'd think there is a much larger chance of cracking this piece. If I remember correctly, there was a website somewhere where a guy recommends lifting from the center of this member... I personally would not follow that advise. The manual does NOT indicate that the center of this member should be used for lifting... at all. It does show the ends of this member as "optional" points, but not the center... so... very simple, DO NOT lift from the center of that member... the manual is certainly clear on this.
I've pointed this out before, in a Mustang forum, guys were saying that you could lift from the center of the rear axle even though the Ford manual says not to do so... and then a few weeks later there were posts from guys crying that their axle housing were now leaking etc... they should have listened to Ford as opposed to listening to some kids on the internet.
My attitude with my C6... the last thing in the world I want to do is have to bring my car back to the dealer... hasn't been there yet and hopefully never will be... so by following the GM manual to the letter and using only the designated "preferred" lifting points, I figure this gives me the best shot at keeping the car OUT of the dealership... it's the "safe" way to go and worth the extra effort, at least for me, even if it IS "overkill"... it's good peace of mind in any case.
