please help
Old Dec 28, 2008 | 03:27 PM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by tailshe
well itryed the second fob and still no
it was in reverse...
1. You have manual transmission with clutch, right?
Not trying to be a smarta$$. Once, I nearly left my 09 turned off in Drive overnight. Vehicle goes into Accessory Mode if you stop the engine and you're not in Park. That might drain the battery.
2. From the manual: "Cell phone chargers can interfere with the operation of the Keyless Access System. Battery chargers should not be plugged in when starting or turning off the engine."
3. Also from the 09 manual: "If the vehicle has a manual transmission, it is recommended that you move the shift lever to Reverse and set the parking brake after you turn off the engine..."
Old Dec 28, 2008 | 03:35 PM
carnut08's Avatar
carnut08
Here's my .02:
Check the battery cable connections to the battery. Make sure they are clean and tight. If they are, don't screw around. Just replace the battery and you'll be back in business.
Once a battery gets too low, your electronics get really stupid. It's like a Corvette on drugs. No amount of fooling around will fix the problem until your electronics get the correct amount of current from a good battery.
Old Dec 28, 2008 | 03:38 PM
dpigguy's Avatar
dpigguy
Originally Posted by ALZ51
Sorry about that typo. I have an 07 MZ6. Thanks for that. I'm an idiot!
I wouldn't beat yourself up - these cars are a collection of extremely sensitive electronic systems and they can do very strange things. It still sounds like you have a battery issue. You can find the specifics for what battery is required in the specifications section of your manual, which as others have said, should be read - its a good source of information. Even then, these cars can do a lot of wierd things that aren't covered there as well!
Try the jump start per the procedure in the manual and then have the battery and charging system tested and repaired/replaced as needed if that proves to be the issue. There may be some prorated rebate on it but I do not know for sure in your case. Good luck - you'll get it figured out and running like a top soon.
Old Dec 28, 2008 | 04:21 PM
K9KUZ's Avatar
K9KUZ
I don't understand why you are concerned about the cost of towing...this is not a cheap car. Why not join AAA, and get the jump starts and towing free. Some good maps too.
Old Dec 28, 2008 | 04:31 PM
Dick4295's Avatar
Dick4295
Default Car not starting
If you have a cell phone or some other remote in the same pocket as your fob,the car won't start. It happened to me today. I removed the cell phone and it started.
Old Dec 28, 2008 | 04:35 PM
Vette_DD's Avatar
Vette_DD
Three or four other options to try first. Why spend ANY money you don't have to?
Old Dec 28, 2008 | 05:16 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
I'm sorry...but owners who don't read their manuals deserve to be locked in their cars for EVER !!!!!!!
Just incase anyone doesn't know...it's the black book located in the glove compartment, and it also has some pictures in it.
Old Dec 28, 2008 | 05:30 PM
GotVett?'s Avatar
GotVett?
. . . not to mention taking a chance of the tow truck/operator really messing things up!
Old Dec 28, 2008 | 06:07 PM
Vette_DD's Avatar
Vette_DD
It's not unusual for a used car to get to the new owner with no owner's manual in the car at all.
Lighten up.
BTW, most manuals are not black.
Old Dec 28, 2008 | 06:15 PM
bencini231's Avatar
bencini231
Originally Posted by tfkrato
You probably have a dead battery.
To open the doors from the inside with no power simply pull up on the manual levers on the floor next to the door.
To open the car from the outside with no power use the key. The key entry is above the license plate. There is a pull tab inside the trunk on the left side to manually open the driver's door from the trunk.
Read the manual.
Old Dec 28, 2008 | 06:35 PM
JERGENSEN LS3
my manual is black, and anyone can get a new manual from any Chevy dealership...not very hard to do ! Just my 2 cents
Old Dec 28, 2008 | 06:44 PM
Purdue's Avatar
Purdue
I have the paper manual in my car as well as an electronic copy saved on my computer .
Old Dec 29, 2008 | 12:54 AM
  #33
NARIMAN's Avatar
NARIMAN
finaly after many times trying to jump up it started
thanks to all of you
Old Dec 29, 2008 | 04:43 AM
  #34
bolivar's Avatar
bolivar
Buy a new battery.
Old Dec 29, 2008 | 10:17 AM
  #35
RED HUSKY's Avatar
RED HUSKY
If its still under warranty chevy pays for the tow. Just in case it happens again. Good luck
Old Dec 29, 2008 | 10:25 AM
  #36
z51vett's Avatar
z51vett
i started my car 2 days ago
so today my wife gets in the car and she cant start the car and cant open doors too, she was stuck in the garage alone could not do any think.
any ways i found her so somehow trunk opened and she got out
what is wrong here? i had it in reverse gear and all and it started two days ago, all i know that iam not driving as much
is it a battery, because it sayz no fobs detected
can i jump start the car? is battery under waranty?
please help me not sure what to do here
and why do i have a key, is thre a way to start with a key?
Check battery terminals to see if loose and check grnd wires on wiring harness. Seems their was a tech bulletin on this.
z51vett
Old Dec 29, 2008 | 02:01 PM
  #37
hkunz's Avatar
hkunz
You might try getting an inexpensive battery charger at an auto parts store. Mine was doing all the things you stated, no fob, random lights on, radio not working right, doors won't open, etc. We put a full charge on the battery and it hasn't happened since. I actually had to disconnect the battery from the car to charge it, since one headlight kept coming on.
