please help
Old Dec 28, 2008 | 11:55 AM
NARIMAN's Avatar
NARIMAN
Default please help
i started my car 2 days ago
so today my wife gets in the car and she cant start the car and cant open doors too, she was stuck in the garage alone could not do any think.
any ways i found her so somehow trunk opened and she got out
what is wrong here? i had it in reverse gear and all and it started two days ago, all i know that iam not driving as much
is it a battery, because it sayz no fobs detected
can i jump start the car? is battery under waranty?
please help me not sure what to do here
and why do i have a key, is thre a way to start with a key?
Old Dec 28, 2008 | 12:04 PM
tfkrato's Avatar
tfkrato
You probably have a dead battery.
To open the doors from the inside with no power simply pull up on the manual levers on the floor next to the door.
To open the car from the outside with no power use the key. The key entry is above the license plate. There is a pull tab inside the trunk on the left side to manually open the driver's door from the trunk.
Read the manual.
Old Dec 28, 2008 | 12:12 PM
NARIMAN's Avatar
NARIMAN
why would battery die it started fine two days ago and the car is 07 with only 6k miles
would it be covered under waranty?
Old Dec 28, 2008 | 12:20 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Originally Posted by tailshe
Battery's die for various reasons.
If its a stock battery I would think they would give you a proration.
Old Dec 28, 2008 | 12:28 PM
NARIMAN's Avatar
NARIMAN
but can i jump start?
Old Dec 28, 2008 | 12:46 PM
petiebear's Avatar
petiebear
Yes, but read the manual for the correct procedure. I jumped mine with no problem.
Old Dec 28, 2008 | 01:14 PM
AtHomeSoda's Avatar
AtHomeSoda
Default Well.....
Why do you want to mess with jump start... going to the dealer... and shell out MORE money on the same CRAP battery you just had... Just go to Auto Zone, get a battery, 3 year free replacement, and 7 year warranty... install it and be done. Just my .02.
Old Dec 28, 2008 | 01:17 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Is your car a 2005 with a manual transmission where it has to be parked in reverse? "No fob detected" could mean your fob battery is dying or dead. I'd first try moving the fob around in different positions to see if it can be recognized; I'd try using your other fob to see if it works; and, I'd put a new battery in one or both fobs just to be sure they're good.
If the car battery is weak or dead, you may be able to jump start the car. If your battery is bad, I'd have it checked and replaced if necessary. I had to replace the battery in my 2005 C6 after 3+ years of trouble-free service. IMO that's about all you can expect from a battery. You will have to re-index your windows after changing the battery. I strongly suggest you read your owner's manual. Good luck.
Old Dec 28, 2008 | 01:27 PM
ALD_Z06's Avatar
ALD_Z06
If you didn't know how to get out, you may also not know how to turn off the dome lamps on the mirror. Since it's an 07, you DON'T need to be in reverse like the 05's. Just changing the battery without checking what caused it is a mistake. Have a professional check your charging system.
Last edited by ALD_Z06; Dec 28, 2008 at 02:51 PM. Reason: I knew that as I have an 07. I'm a screw up!!!
Old Dec 28, 2008 | 01:31 PM
timd38's Avatar
timd38
FYI, the OE battery is made to higher compliance specifications than an aftermarket replacement battery. Battery warranty is a function of marketing, not batter quality.
Old Dec 28, 2008 | 01:39 PM
NARIMAN's Avatar
NARIMAN
well itryed the second fob and still no
it was in reverse, it is an 07, i cant take it to a professional since a towing a car will cost too much
so first i will try to jump start
if not what kind of battery should i get, is it going by the size?
Thanks for help
Old Dec 28, 2008 | 01:42 PM
Windward08's Avatar
Windward08
This is very true. I always replace with the OEM battery and have real good luck with them.
The aftermarket ones, not so much.
Old Dec 28, 2008 | 01:47 PM
phileaglesfan's Avatar
phileaglesfan
Did you try sticking the fob in the slot in the glovebox? Your battery isn't dead since it is telling you it can't detect the fob. It could also be a sensor in the vehicle that is covered under warranty. Do you have the accessories working (pushing the bottom of the starter button)? If so you may be able to check the battery's volts. If that doesn't work, jump start it, get it to the dealer and let them fix it. It may not be the battery. Reading the owner's manual would be a real good idea also.
Old Dec 28, 2008 | 01:50 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Not true. I can tell you from personal experience that the vehicle battery can be low enough so as not to be able to crank nor even work the door solenoids yet still have the DIC display that no FOBs are recognized.
As a matter of fact, the vehicle battery can be low enough as to cause all sorts of strange behavior
NARIMAN's Avatar
NARIMAN
it did open the trunk with the fob,accesory mod is comming on and the radio is flashing
Old Dec 28, 2008 | 02:18 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by ALZ51
Since it's an 07, you need to be in reverse like the 05's.
NO! NO! NO! That's incorrect. Manual tranny 07s don't have to be put in reverse to prevent battery failure. Read the manual and show me where the 07 manual says that. It's just suggested that you put it in reverse.
2005 owner's manual, page 2-31.
Parking Your Vehicle
(Manual Transmission)
Before you get out of your vehicle, move the shift lever
into REVERSE (R) and firmly apply the parking
brake. Once the shift lever has been placed into
REVERSE (R) with the clutch pedal pressed in, you
can turn the ignition off and release the clutch. If
you attempt to exit the vehicle without being in
REVERSE (R), the Driver Information Center (DIC) will
display SHIFT TO REVERSE and a chime will sound.
Notice: If you do not put a manual transmission in
REVERSE (R) before exiting your vehicle, the
battery will drain and could be damaged. Always put
a manual transmission in REVERSE (R) before
shutting off the engine and exiting the vehicle.
2007 owner's manual, page 105.
lever into REVERSE (R) and firmly apply the
parking brake. Once the shift lever has been
placed into REVERSE (R) with the clutch pedal
pressed in, you can turn the ignition off and
release the clutch.
Old Dec 28, 2008 | 02:24 PM
VettedCandidate's Avatar
VettedCandidate
Not true...this happened to me and it was the car battery.
To please help
Old Dec 28, 2008 | 02:48 PM
NARIMAN's Avatar
NARIMAN
ok i just tryed again
it opened the door as i walked to the car with my fob in the pocket
accesory mod is not comming on
the lights in the car are working
even my exaust cutout is opening and closing
the seats are moving very slow
trunk and doors would not open again with fob
the fob is working, i tryed two of them
when i start the car it shows lock and sayz no fob detected
i was looking for where to put the key in glove box but could not find anything
i will look in the manual
Thanks so much to all of you
Old Dec 28, 2008 | 02:51 PM
KenHorse's Avatar
KenHorse
You mean when you TRY to start the car, yes? It doesn't actually crank, correct?
Putting the FOB in the slot in the glovebox with NOT solve your problem. The car's battery is low.
Charge it and I bet everything comes to life
Old Dec 28, 2008 | 02:52 PM
ALD_Z06's Avatar
ALD_Z06
Sorry about that typo. I have an 07 MZ6. Thanks for that. I'm an idiot!
