cold air intake???
Old Dec 30, 2008 | 10:29 PM
noenvybu's Avatar
noenvybu
Default cold air intake???
I have an 08 vert,considering a cold air intake...what kind of results or improvements should I expect, and any recommendations on brand??
Vararam Snake-charmer,K&N,or others...any help would be appreciated
Old Dec 30, 2008 | 10:35 PM
spin-doktor's Avatar
spin-doktor
the stock air intake on 2008 and newer LS3 vettes is pretty well designed and flows almost as well as an aftermarlet CAI. You can shell out 350 - 500 bones on a good aftermarket unit but the improvement will be negligible.
Old Dec 30, 2008 | 10:40 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Snake Charmer
Old Dec 30, 2008 | 10:41 PM
c6 batmobile's Avatar
c6 batmobile
The vararam has proven results. 3 tenths in the quarter mile gauranteed. You wont get more than about 12-20 hp but you will defintly notice a difference above 60mph.
Old Dec 30, 2008 | 10:49 PM
Wayne O's Avatar
Wayne O
CF Senior Member
The results won't be dramatic but the benefits of going to a true, bottom-feeding cold air intake are undeniable...sucking-in cooler air does help. On its own don't expect miracles. I look at a CAI in the context of it being one component in your overall modification plan.
There are several well respected and popular brands. Vararam is a popular intake. I prefer the Lingenfelter high-flow intake.
As with any mod, there are pros and cons. Not only are there warranty considerations but you will have to be especially cautious when driving through deep standing water. The owner’s manual cautions against driving through deep standing water with the stock intake but a bottom-feeding CAI will make your car even more susceptible to ingesting water and risking hydrolock. My LPE intake handles heavy rain without a problem but I avoid fording any streams.
Old Dec 30, 2008 | 10:52 PM
e weezie's Avatar
e weezie
I have the Vararam on my 08 and would recommend it. My car pulls much harder from second gear on up.
Old Dec 30, 2008 | 11:01 PM
Cherokee Nation's Avatar
Cherokee Nation
Default Cold air Intake
I like the K&N air charger,more HP & i gained about 3 mpg & you do not have to worry about WATER plus K&N has been around for a long long Time & they do guarantee that you will get the HP that they say.
Old Dec 31, 2008 | 12:00 AM
pokerplayer's Avatar
pokerplayer
Vararam.....works great for me. Just like the other guy said....pulls hard 2nd on up very noticeably.
Mike
Old Dec 31, 2008 | 12:05 AM
danl72's Avatar
danl72
You will get many different opinions. You will have to make the decision based on recommendations and ultimately your preference.
Old Jan 1, 2009 | 01:06 AM
noenvybu's Avatar
noenvybu
Do these cold intakes void the warranty???
Old Jan 1, 2009 | 08:08 AM
Agent White's Avatar
Agent White
St. Jude Donor '10-'12-'13-'14
You might want to chech out the Callaway Honker also. It is built with better quality thatn several of the others.
Old Jan 1, 2009 | 08:15 AM
Swiftrider08's Avatar
Swiftrider08
I keep saying over and over that the stock 08/09 air filter intake is the same as what is used on the 505 hp Z06. That makes it good enough for me. Much better mods you can spend your money on for what they are getting for these things.
Old Jan 1, 2009 | 10:50 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Jan 1, 2009 | 10:59 AM
glennhl's Avatar
glennhl
The stock LS3 intake is an excellent piece, except for one problem. It does not take in cold air. You can do the free mod by propping the radiator shroud open and that helps some. Then you can put on a cover to segregate the engine air from the air coming in through the propped open shroud.
It's my opinion that the aftermarket inlets are ONLY better because of cold air, not due to lower pressure drops. But cold air is worth a lot. If you lower your inlet air by only 30 degrees, you will pick up approximately 18 hp.
Old Jan 1, 2009 | 11:38 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Feb 12, 2009 | 11:32 PM
siffert's Avatar
siffert
Great post and so true!
Really? I never saw a guarantee on the Vararam web site that you will get "guaranteed .30 in the quarter mile".
Do you get double your money back if you only pick up one or two tenths?
How do you know what hp you pick up from the VR when it cannot be measured on a dyno?
Old Feb 12, 2009 | 11:57 PM
nwc6's Avatar
nwc6
In stock form, the PCM starts pulling timing at 86 degrees Inlet Air Temp.. If you are not going to do more mods, ie. headers/cam..The stock filter assy will be fine if you get cooler air to it.
To cold air intake???
Old Feb 13, 2009 | 12:30 AM
Turbooo2u's Avatar
Turbooo2u
I have a Z06 and when I saw the stock air filter, I asked myself how any air could get to the engine. Thru on a VARARAM and this was a difference you could feel.
Old Feb 13, 2009 | 12:35 AM
RanGer498's Avatar
RanGer498
i went from a vararam to a haltech ..feels almost the same to me .
Old Feb 13, 2009 | 05:58 AM
Red Rochester
but they do not have a unit for the LS3 yet ?
