Bigger CCW wheels?
Old Dec 31, 2008 | 03:33 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Default Bigger CCW wheels?
I'm considering getting CCWs (SP18) and was going to get OEM sizes but they mentioned I should consider getting 18X9.5 and 19X11 and putting 275 and 305 tires on them. It would be nice to have wider tires since I have 460 rwhp, but part of me says to stick with OEM sizes. Has anyone gotten those sizes and how do they fit? Pics would be super as well.
Thanks.
Old Dec 31, 2008 | 03:46 PM
keyplyr's Avatar
keyplyr
You can do that. They'll fit terrific. John will use the correct offset, he knows what he's doing. I'm running more than that on C6 fenders:
Front
19X10 CCWSP16A 1 piece forged polished aluminum
275/30-19 TOYO Proxes T1r
Rear
20X11 CCW SP16A 1 piece forged polished aluminum
305/30-20 TOYO Proxes T1r
Old Dec 31, 2008 | 04:14 PM
NYC6's Avatar
NYC6
I have the 505 (19 and 18)wheels in those sizes. On their 11" wheel you can mount 325 tires(Z06size) as I have.
Old Dec 31, 2008 | 06:59 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I run 19 X 11 in the rear 505a and with 295 on the rears you have room for more
Old Dec 31, 2008 | 11:05 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
I have Chromed CCW T10's. Purchased from Atomic Autosports in Florida. Great Forum Vendor by the way.
18X9.5 w/275-35 Fronts and 19X13 w/345-30 Rears (Z06 Fenders) Michelin PS ZP's.
CCW advised me that 9.5 wide fronts were the widest that would clear Z06 Brakes and still stay under the fender.
Before I decided to add the wide rear fenders I considered 11" wide rears w/325's but was told by several tire shops (Forum Vendors and Local) that they could not get them to mount. Although clearly, it can be done.
Pay attention to the front-to-rear diameter relationship. Active Handling can be adversely affected if the ratio is too far off. Tire Rack is a great reference source for tire diameters.
Personally, I would avoid going to any aspect ratio smaller than 30 as the ride gets pretty harsh even with the F55 suspension. But I'm old.
Old Jan 1, 2009 | 12:37 AM
Zteve's Avatar
Zteve
I'm running CCW C14s 18*10 front 18*11 rear with 275/35/18 and 305/35/18 and they fit perfect. No rubbing what so ever.
Old Jan 1, 2009 | 08:55 AM
St.Char's Avatar
St.Char
Hey Eric, can't believe you're still looking for wheels, did you get your others sold yet? Anyway, here is my 19X9.5 and 20X11 combo. I'm running 275/30/19 -Front and 305/25/20 -Rear w/no issues. Get the bigger combo, you'll like the the look and performance better.
Old Jan 1, 2009 | 09:16 AM
Wayne O's Avatar
Wayne O
CF Senior Member
IMO go with the wider sizes. For street driving I use CCW wheels 9.5” x 18” front - 11” x 19” rear with Goodyear Eagle F1 Supercar EMT’s...275/35ZR18 front - 325/30ZR19 rear (stock Z06 tires). You could go with 10" wide front wheels as well.
I was traction challenged on the OEM C6 wheels/tires and going to the Z06 sized supercar tires made an improvement. Your car will grip better under acceleration and braking and it will handle and 'track' better through the curves. I felt the larger wheels and tires helped soak-up small chatter bumps (like expansion joints on a curve) better too. If you have any future plans to go to a big brake setup, talk with John (at CCW) first as it will affect wheel selection.
The rear Z06 tires protrude just slightly from the rear body panels but it's truly negligible. I wouldn't have any hesitation...it's a good move!
Old Jan 1, 2009 | 09:56 AM
smackdown's Avatar
smackdown
Hi what wheels are those?? ( name brand )
Old Jan 2, 2009 | 08:48 AM
vettecop1125
CI 7-8 Veteran
Thanks for all the info. It really gives me something to consider.
Greg - I just sold my other wheels earlier this week, so now I'm in serious shopping mode.
Old Jul 25, 2009 | 11:22 AM
pinky balls's Avatar
pinky balls
Default rims and tires
was looking at your pic of silver c6 looks good had a ? running that combo could you lower the car at all.
Old Jul 25, 2009 | 11:24 AM
pinky balls
To Bigger CCW wheels?
