Push Pin Removal Tips...
Old Jan 2, 2009 | 11:24 PM
Scubaholic's Avatar
Scubaholic
Default Push Pin Removal Tips...
Any tips on the removal of the "push pins" that secure some of the plastic shrouds and wheel wells throughout the C6 Corvette? I have a couple of mods to take care of over the next couple of weeks and I don't want to tear up the push pins. I figure there has to be a proper technique that won't require mutilation. And if by chance I need some replacements, anyone I can go to besides a GM dealer for these?
Old Jan 2, 2009 | 11:28 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I used a pair of wire cutters, the flat end either side slips easily behind the pin and squeeze a little then pull them out. Was simple.
Old Jan 2, 2009 | 11:34 PM
walker3's Avatar
walker3
Pepboys has the tool for less than $7 - a forum member told me about it - went purchase one and works great - did not break any pins when removing (they also sell the exact pins for a couple of bucks also).
Old Jan 2, 2009 | 11:35 PM
johnodrake's Avatar
johnodrake
Moderator
I use a V notched pry tool. You can buy bulk here a lot cheaper than the Chevy parts store. http://www.thefastenerwarehouse.com/...age/566976.htm
car2fast4you's Avatar
car2fast4you
I use a pair of side-cut pliers like these:
http://www.mikewye.co.uk/ProjectFiles/SideCutPliers.htm
You can buy pliers like this for a little as $5.00 for small ones.
Just grab the head of the pin with the pliers & wiggle it right out.
Old Jan 2, 2009 | 11:36 PM
HANNY's Avatar
HANNY
wire cutter/dikes work well as long as you dont get jiggy with em and dont cut them in half. I found the push pins at oreilys are very similiar to the O.E. ones if you tear any up. They arent exact but are close. good luck, paul
Old Jan 2, 2009 | 11:39 PM
VettedCandidate's Avatar
VettedCandidate
Pull?
Old Jan 3, 2009 | 07:33 AM
Quasar21's Avatar
Quasar21
Great tip. Thanks for the link.
Old Jan 3, 2009 | 07:59 AM
fred_S's Avatar
fred_S
Can I please get a lift on this thread. It seems a lot of people with push pin know how are reading this.
I plan on installing a Callaway Honker and a pre-cut shroud, you need to remove some pins from the shroud, and re-use them when you assemble everything. I have never done that, can anyone please let me know, maybe with a link, which pushpins I need, because I'm almost certain I'm going to demolish a few in the removal process.
Sorry again, not trying to hijack this thread.
Old Jan 3, 2009 | 10:19 AM
rws.1's Avatar
rws.1
V tipped old style weed remover...
Old Jan 3, 2009 | 11:35 AM
quacktheduck's Avatar
quacktheduck
I use a tiny flathead screwdriver to pop it up slightly (there's a small groove on each where i can insert it) then follow that with needle nose pliers to remove it all the way, works like a charm for me and haven't broken one yet.
Old Jan 3, 2009 | 11:47 AM
07MontRedcp's Avatar
07MontRedcp
I have the technique down to the point that I ONLY need the flat blade screw driver. Using the proper size to lift the pin and then TURNING the blade clockwise (I'm right handed) while moving the handle down to pry the pin out works very well for me.
BJK
Old Jan 3, 2009 | 11:50 AM
Wayne O's Avatar
Wayne O
CF Senior Member
As mentioned, go to about any auto parts store and buy a pry tool. Remove one of the push pins and take it to an auto parts store (or even the dealership parts department) to find the correct match. You may not need them but it's wise to buy some extras.
I remove the airbox on my LPE CAI frequently to clean and change the filter...I think there's something like 9 or 11 push-pins involved. Occasionally, I'll have to replace a worn or broken one. It's not a big deal.
To Push Pin Removal Tips...
