Dic question
Old May 18, 2009 | 10:34 AM
3dg4r's Avatar
3dg4r
from reading this I think you might have a defective DIC...
Old May 18, 2009 | 10:51 AM
LMB-C6's Avatar
LMB-C6
Did you try turning off the Auto Volume feature on the radio?
Old May 18, 2009 | 11:39 AM
deanm11's Avatar
deanm11
Thanks- I have and just to be sure, tried it again. Zero difference.
Old May 18, 2009 | 03:19 PM
deanm11's Avatar
deanm11
Second dealer acknowledges the problem. I think that I will at least get an attempted diagnosis/fix. They said they would likely call me tomorrow.
Old May 18, 2009 | 03:31 PM
VET4LES's Avatar
VET4LES
Originally Posted by hanny
that sounds very weird?????? not normal, IMO
Old May 27, 2009 | 11:14 AM
deanm11's Avatar
deanm11
Update: Dealer replaced driver's door speaker. No difference; no surprise to me. We agreed they would continue to try to fix. I believe they are going to call to some central tech help. I did hear some of the noise in the passenger's door speaker as I was demonstrating the noise with the radio on ... I had previously thought possibly left door speaker only.
Old May 27, 2009 | 11:27 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
Originally Posted by deanm11
The dealer (largest Corvette dealer in North Jersey) said that wouldn't fix it. The initial service writer acknowledged the problem but then the lead service man got involved. He said that he didn't think he could justify using GM's money to throw parts at it. My real beef is the noise when the radio is on. At modest volume levels, driving down the road, the noise is about as loud as the radio signal. It has got to be either an amp or the way the DIC noises/etc are interfaced into the system. No way it is the head unit. I went upstairs to the Corvette showroom and got the fob to an '09 with Bose (but also with NAV unlike mine) and the radio had no such noise.
I'm thinking about trying one more dealer.
Must have been Paramus Chevy
Old May 27, 2009 | 03:16 PM
deanm11's Avatar
deanm11
The dealer (#2) worked with some central tech area... and per tech's instructions, they are overnighting a new amplifier in... will update tomorrow. Now I think this a good chance of being a fix.
Old May 27, 2009 | 03:47 PM
Tree1985's Avatar
Tree1985
I discovered the "feature" of console, beeps and DIC tones going through the car stereo after I had my Pioneer AVIC installed. There is a separate amplifier control for the beep volume inside the stereo. It sounds like the control wire on the back of the radio for this "feature" may be loose, or a ground for that amplifier went funky...
My guess anyway. New amplifier may fix, but if not, I would check for a bad wire in the stereo connection harness...
Old May 28, 2009 | 02:14 PM
deanm11's Avatar
deanm11
They received the new amplifier and it was not a fix. They are continuing to work with the GM tech people. They asked me to verify that I didn't have any aftermarket electronic equipment.. I presume they are going to be checking grounds, clean power, etc.
Old May 28, 2009 | 07:07 PM
deanm11's Avatar
deanm11
When you refer to a separate amplifier control above - you mean in the stock radio or in the Pioneer? If the former, then maybe that head unit is going to have come out after all...
Old May 28, 2009 | 07:12 PM
mongooseC6's Avatar
mongooseC6
Don't be so hard on yourself. There is no such thing as a dumb question.
Old May 28, 2009 | 07:22 PM
  #33
deanm11's Avatar
deanm11
Old May 29, 2009 | 06:06 PM
  #34
deanm11's Avatar
deanm11
Checking grounds didn't yield anything. Gm tech is having them pull various modules on the theory that possibly one is backfeeding, causing the noise. (Monday)
Old May 29, 2009 | 08:40 PM
  #35
Mad*Max's Avatar
Mad*Max
It's normal, if you want to call it that, I can notice it because I keep my stereo very loud and if I am in between songs I can notice it.
Old May 29, 2009 | 08:50 PM
  #36
deanm11's Avatar
deanm11
I do think it is in a number of cars.. but the one new '09 Vette I checked didn't have it. With the car off (accessory mode), can you hear it with the radio on the first or second volume 'click' ? At that volume level, the ticking/noise is louder than the radio signal.
Old May 30, 2009 | 11:23 AM
  #37
deanm11's Avatar
deanm11
Default Onstar ?
It seems this problem is reported most often on 08s. Is there a dedicated amplifier for onstar ?
Dean
To Dic question
Old May 30, 2009 | 03:29 PM
  #38
markcz's Avatar
markcz
You can find all of the radio and onstar schematics here, but no, only one amp.
Old May 30, 2009 | 03:50 PM
  #39
deanm11's Avatar
deanm11
Thanks for the info
Old Jun 9, 2009 | 12:14 PM
  #40
deanm11's Avatar
deanm11
GM tech finally had the dealer change the head unit/radio. No change. They had checked an '09 (they believe a coupe) right after I had dropped the car and observed no noise issue. After they changed out the radio, they tested two in stock '09 convertibles and they have the same noise/issue that my car has. Gm tech believes there could be an issue specifically with convertibles in regard to the antennae location. I'm going to pick up the car dn supposedly GM tech is going to work on the issue on their own. (I didn't verify, but this must mean that GM tech has verified the problem in a car themselves)
