Where are the build codes listed in the C6 Corvettes-( 1996 C4 has them on the battery cover door) Thanks
Originally Posted by JoesC5
If you're talking about the options on the car, they are on the backside of the glovebox door.
Look closely though, some knew where they were and still missed them. Extreme left side of the glovebox door. And they're called RPO codes, although I've forgotten exactly what those initials stand for.
If I remember correctly they stand for Regular Production Order.
From: Why are there squished peanut butter cups in my underware?
Originally Posted by JimTN
Most here can read.
But appearently you are unable to comprehend the supporting statement within the original question.
Maybe you're from Rio Linda. I'll walk you through it.
The original question was; "Where are the build codes listed in the C6 Corvettes"
It sounds like the OP is asking where the RPO sticker is. (Or as *89x2* correctly identifies as the SPI Label.) To which others have responded with the correct location.
However, *89x2* and I were pointing out to the OP, that his assumption of the C4s battery location is incorrect.
I tried to use simple words for you to read. Don't be afraid to ask a kindergarden student to help you with comprehension.
Read his original post again. Tell me where in there he made any statement about where the battery was located.
