Jacking PuckS ???
Old Feb 12, 2009 | 09:46 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Originally Posted by clydetrb
No difference. As you have already noticed, they fit and work the same.
Old Feb 12, 2009 | 11:29 AM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
Originally Posted by slacker1201
Does anyone know if these will fit an 04 Z?
Yes they will....I had them on my 02Z.
Old Feb 12, 2009 | 11:33 AM
DA KAR's Avatar
DA KAR
Originally Posted by Wayne O
FWIW I strongly suggest you do NOT "just leave em' in." There have been several accounts of jacking pucks (left on the car) causing severe body damage when they dragged or snagged on something like a speed-bump.
They're designed for a specific purpose. Don't be lazy, put them in when needed and remove them promptly when you're done using them.
I use the rectangular BMW jacking pucks. To make them easier to remove, I drilled slightly into the center pins and then screwed-in small brass screws leaving the heads sticking-out a bit. The screw heads are much easier to crasp (and pull) with pliers or a Leatherman tool. After pulling the center pins down I use a flathead screwdriver to pry the pucks off the car.
IMO never leave the jacking pucks mounted permanently on your car...you're asking for trouble.
They really don't stick out that much...u can't see them from a side view.I wouldn't be worried about them hitting anything.I've been using them for years with no problems.
Old Feb 12, 2009 | 12:09 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
Old Feb 12, 2009 | 01:20 PM
ChefMark's Avatar
ChefMark
Do you really need Jacking Pucks? Or is there another one of the forums **** retentive threads from us **** retentive Vette owners.
Old Feb 12, 2009 | 01:25 PM
FM's Avatar
FM
Seems to me there are 3 choices:
a) Jacking pucks.
b) Mechanics who know how to lift a Corvette and pay attention.
c) a and b above.
Old Feb 12, 2009 | 01:30 PM
ChefMark's Avatar
ChefMark
[QUOTE=FM;1568920055]Seems to me there are 3 choices:
a) Jacking pucks.
c) a and b above.[/QUOTE
OK?
Old Feb 13, 2009 | 03:38 PM
bad2000z's Avatar
bad2000z
I just got the round BMW ones yesterday. They are only 2.75 dia .5 thick. I can't picture these causing any body damage if left in.
Old Feb 13, 2009 | 03:52 PM
Bobz08C6's Avatar
Bobz08C6
Originally Posted by FAÇADE-C6
BMW Rectangular Pads:
(L= 3.5" x W= 2.25" x H= 1")
Order here . . .
http://www.bavauto.com/fland.asp?par...1+71+8+268+885
Part # 51 71 8 268 885
(For a 2004 BMW 325Ci)
I bought mine last summer for $6.95 each. Now that they realize they fit a C6 the price doubled.
I then bought the square ones because the round ones didn't seat on my jack stands very well. The square ones do. So now I have 2 sets. The square ones don't snap in for a permenant fit but I use them in my jack & jack stands.
Buy these round or square or take the hockey puck recommendation. I didn't do the hockey puck thing because I was concerned that as the rubber aged it might get brittle and break under the weight of the car. Maybe not true but that's how I feel.
Old Feb 13, 2009 | 05:11 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by MurphMan2
Note to self..............must order a set of these soon.
I got a real nice set on e-bay. $25 shipped.
Same here. I took them a few weeks ago when I was getting new wheels mounted. The shop normally used rubber blocks. The owner was very interested in my "custom" pucks and wanted to know where he could get some for his shop since he says he is doing more Corvettes all the time.
It seems the guy who was selling them on the-auction-site-that-shall-not-be-mentioned-but-buys-ads-here doesn't seem to be selling recently. They are easy to make. A search finds many threads and, to confirm the other answers, the Z06 pucks have a very slightly longer stem. They will fit any C5-C6 while the coupe version only fits the coupe/vert if they are designed to a tight tolerance on the stem length.
Old Feb 13, 2009 | 07:08 PM
Mike's LS3's Avatar
Mike's LS3
Same here, hard rubber hockey pucks with eye bolts installed in them. Just slip them in and make a 1/4 turn and they stay. I paid $ 23 for four of them shipped to my doorstep.
Old Feb 13, 2009 | 07:19 PM
keyplyr's Avatar
keyplyr
Originally Posted by knick
make your own ....hockey pucks
(photo courtesy of 97vette.com)
Old Feb 13, 2009 | 08:58 PM
  #33
freyke's Avatar
freyke
IMHO, that's ghetto, I'm just say'n.
Old Mar 16, 2009 | 11:57 PM
  #34
kev1n's Avatar
kev1n
Do the bimmer pucks come in pairs ? or is it 1, and you need to order a quantity of 4 ?
Old Mar 17, 2009 | 12:26 AM
  #35
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Unfortunately, they do not come in pairs and must be purchased individually - 4 total.
