emergency key doesnt work
Old Feb 21, 2009 | 07:13 PM
phil068's Avatar
phil068
Default emergency key doesnt work
A friend has a C6 and the battery has gone dead during the winter. He tried to open the trunk using the emergency key but nothing happens. The key turns, but the trunk does not release. Is there some trick to getting it open? Is this a common problem?
Old Feb 21, 2009 | 07:21 PM
turmat's Avatar
turmat
You are not turning far enough. This lock works VERY hard. Be careful...but turn further.
Old Feb 21, 2009 | 07:23 PM
candlemuse's Avatar
candlemuse
Old Feb 21, 2009 | 07:25 PM
Vette_DD's Avatar
Vette_DD
There have been threads posted here that indicated there was a problem with the installation of some part of the connection at the factory on some C6s.
Maybe someone else here can provide more info., including a link to the pics showing what the problem might be,
Old Feb 21, 2009 | 08:04 PM
CAP94's Avatar
CAP94
turn key harder
Old Feb 21, 2009 | 08:12 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
If turning the key harder/further doesn't work check to make sure the cable is attached to the rear pull down motor. There is reports that this cable is not connected.
Old Feb 21, 2009 | 08:16 PM
johnodrake's Avatar
johnodrake
Moderator
If the lock cannot be made to work, you can jump the battery by connecting to the positive pole of the starter and the frame. This should give enough juice to allow the fob to open a door.
Old Feb 21, 2009 | 09:07 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If this is the problem, good luck...
http://forums.corvetteforum.com/1567229922-post34.html
Old Feb 21, 2009 | 09:12 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Hopefully, you don't have the problem Ft Morgan shows. Otherwise, if this is the first, or even the tenth time using the key, be very careful as said above, but just keep working the key. It really is very difficult to turn at first (or tenth).
What your friend doesn't want to do is break off the key in the lock. Then, you've got more problems. Obviously.
Old Feb 22, 2009 | 12:59 AM
cclive's Avatar
cclive
And this gives me a good excuse to bring up this thread again!
http://forums.corvetteforum.com/c6-c...metal-key.html
Old Feb 22, 2009 | 02:13 AM
Daniel Redfoot's Avatar
Daniel Redfoot
Been there-done that..
Most is already answered herein bit a little mo detail HERE:
http://forums.corvetteforum.com/c6-c...-heads-up.html
Old Feb 22, 2009 | 07:44 AM
AFVETTE's Avatar
AFVETTE
Put a little downward pressure on the hatch while turning the key.
Old Feb 22, 2009 | 08:56 AM
maxp's Avatar
maxp
how can he do that if he can't open the hatch?
Old Feb 22, 2009 | 09:11 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
oh don't be so practical, max!
Old Feb 22, 2009 | 09:39 AM
maxp's Avatar
maxp
sorry, what was I thinking
Old Feb 22, 2009 | 09:41 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Feb 22, 2009 | 10:34 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
Hmmm.......... yet another thing I must remember to try, along with the cruise control and the wipers.
To emergency key doesnt work
Old Feb 22, 2009 | 10:53 AM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
and squirt a fine film of WD40 on the key first.
Old Feb 22, 2009 | 01:05 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Can't believe I did not say after he gets the hatch open by what ever means. By this time he should have smashed in the rear glass, one problem solved.
Old Feb 22, 2009 | 03:00 PM
Canuckvette's Avatar
Canuckvette
Cruising
I just had the same problem with my '07 roadster. The dealer suggested that I have the car towed to the dealership for repairs. Thanks to johnodrake for the great info ! I jacked up the right side of my vette and hooked up my battery charger to the starter post. I had the door opened in 5 minutes! As it turned out, the dealer forgot to hook up the emergency cable when they changed my trunk latch assembly under warranty. I re-attached the cable with a set of needle nose pliers in another 5 minutes. Note to self: leave hood open a bit while storing vette.
