Pirelli PZero
Old Feb 23, 2009 | 01:43 AM
supervette26's Avatar
supervette26
Default Pirelli PZero
My stock tires are pretty much done with and I was looking at buying the Pirelli Pzero's.....
Does anyone have these on their car? If yes, what are your thoughts?
ADDED TO ORIGINAL POST:
On my stock run flats every time i hit a pothole or and type of irregular cement my steering wheel moves on its own and it makes a lot of noise....
Are either of these gonna happen with the Pirelli Pzero's?
Old Feb 23, 2009 | 02:42 AM
keyplyr's Avatar
keyplyr
Last time I looked they were difficult to find.
Old Feb 23, 2009 | 03:53 AM
User 81424's Avatar
User 81424
I had them on my C5 Z06, they are fine tires.
Old Feb 23, 2009 | 09:59 AM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
tread wear is rapid... good tires though... sticky
Old Feb 23, 2009 | 11:39 AM
Wah's Avatar
Wah
You are not looking at the PZero Corsa, are you ?
I have no experience with the regular PZero.
Old Feb 23, 2009 | 12:07 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Indeed.
Old Feb 23, 2009 | 12:15 PM
WaFp's Avatar
WaFp
Have the Nero on my '01 Mustang GT and they are awesome! Have about 20k on them and they have a little more than half the life left on them. Don't have any exp with Corsa.
Old Feb 23, 2009 | 01:37 PM
mforman42's Avatar
mforman42
Not the same tire. There are P Zero, P Zero Corsa, P Zero Nero, P Zero Assimetrico, P Zero System, etc. The "just" P Zero is the version I'm assuming was referenced in the original post. It is an appropriate non-run flat replacement for the C6 tires.
I have the 20 inch versions on my Jag XF Supercharged, and I reall like them. They're relatively sticky, the ride is reasonable, and the responsiveness feels quite good. They aren't as noisy as my Goodyear F1 SC on my C6, but they aren't quiet either. (as with the GYs, pavement that has been grooved for rain run-off is the worst)
Hope this helps.
Old Feb 23, 2009 | 02:07 PM
BIG Dave's Avatar
BIG Dave
Isn't Michelin standard equipment on all 2010 Corvettes? (or is that just a rumor?) Anyone have expereince with Michelins on a C6? I need new rubber too and was going to check out Michelin...
Old Feb 26, 2009 | 03:12 AM
supervette26
bump.... i added some more to my post....
To Pirelli PZero
