Which Brake fluid?
Old Mar 6, 2009 | 04:31 PM
ngo449's Avatar
ngo449
Default Which Brake fluid?
Hi Guys & Gals,
Which brake fluid are you using for the 07, C6 w/ /Z51 package.? I went to the dealer & the guy doesn't know which brake fluid. I have use dot 4 for the last 2 years. It seems like I have to fill my brake fluid every 6 months (1/2 to 3/4 quart). Is this normal? Thank you for all of your advice.
Old Mar 6, 2009 | 05:38 PM
blkc6z51's Avatar
blkc6z51
Originally Posted by ngo449
Hi Guys & Gals,
Dot 4 is fine, but I don't think you should have to add any fluid. I have never had to add any and I have an 05 with 25000 mi on it.
Old Mar 6, 2009 | 05:44 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Dot 4
Old Mar 6, 2009 | 05:49 PM
switchplanner's Avatar
switchplanner
Per my '08 owners manual, Delco Supreme 11 Brake Fluid or equivalent DOT-3 brake fluid.
Old Mar 6, 2009 | 05:57 PM
07silvervette17's Avatar
07silvervette17
From: premium smd led lights with lifetime warranty bc
You will have to add as the pads wear and the piston extend out drawing more fluid out of resevoir, The same as when you put new pads in and when forcing back pistons the fluid level will rise in the resevoir! That is why its a good reason to bleed out brakes when changing pads. Dot 4 is good but i use dot 5.1 [not dot 5 that is synthetic]
Old Mar 6, 2009 | 07:45 PM
GrandSportGirly's Avatar
GrandSportGirly
I just flushed mine again and put some new pads since I track my car, I use Brembo DOT 4 and it works awesome.
Old Mar 6, 2009 | 08:47 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
You did it yourself?
I'm mega impressed now.
Old Mar 6, 2009 | 08:59 PM
cclive's Avatar
cclive
1/2 to 3/4 of a quart every 6 months...something is leaking. Use any good Dot 4. The brand won't make any difference in how much you are losing.
Old Mar 6, 2009 | 09:25 PM
GrandSportGirly
You know I am good like that...
I just don't like putting the car on the lift though
Old Mar 6, 2009 | 09:29 PM
photoguy's Avatar
photoguy
I use Prestone dot 4 for brake and clutch fluid.
Old Mar 6, 2009 | 10:14 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I use Motul 600 (Dot 4). If it exceeds on the track then you know it will work well in 'normal' street use.
Old Mar 6, 2009 | 11:33 PM
Mike's Sweet 19's Avatar
Mike's Sweet 19
to CClive,
Where did you find Prestone Dot 4 and about how much for how many oz.
Old Mar 7, 2009 | 12:26 AM
cclive's Avatar
cclive
Originally Posted by Mike's Sweet 05
to CClive,
WalMart and its about $3.00 for 12 oz. Black bottle, vs yellow bottle for the DOT 3.
Old Mar 7, 2009 | 12:56 AM
rdm1465's Avatar
rdm1465
Hi Guys & Gals,
If you are putting that much in, you got a leak someplace. I'd get that checked faster than ASAP.
Old Mar 7, 2009 | 11:27 AM
Wingrider's Avatar
Wingrider
Super Blue Dot 4.
Old Apr 8, 2009 | 07:23 PM
SL41's Avatar
SL41
confused, aren't all dot 4 synthetic already?
Old Apr 8, 2009 | 07:26 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
Originally Posted by Wingrider
Super Blue Dot 4.
To Which Brake fluid?
Old Apr 8, 2009 | 08:00 PM
bsr8129's Avatar
bsr8129
im just confused
Old Apr 8, 2009 | 08:05 PM
johnodrake's Avatar
johnodrake
Moderator
Worry about the brand after you find where the fluid is going!
I use MOTUL RBF600 (DOT 4) in both the Brakes and Clutch.
Old May 13, 2009 | 07:36 PM
coastalcarolina's Avatar
coastalcarolina
From: Myrtle Beach & Greenville, SC -- Hung Like a Republican -- Network Admin/IT
Anyone know where you can buy Motul or Wilwood brake fluid locally?
