Cleaning the Engine?
Old Mar 9, 2009 | 06:34 PM
msaporetti's Avatar
msaporetti
Default Cleaning the Engine?
So I've got a dusty engine on my C6. Last time I steam cleaned my C4 I ended up putting in a new MAF sensor. Is there a special technique required on a C6 for engine cleaning without damaging anything?
Advice appreciated......
Mike Saporetti
Old Mar 9, 2009 | 07:05 PM
TBD's Avatar
TBD
Most engines don't need cleaning. However, should you be so inclined, buy a can of cleaner and follow the instructions. I have cleaned many over the years (no, I don't know just why I did) and here some suggestions: keep the engine RUNNING whilst cleaning, DO NOT use a pressure washer, and (obviously (I hope!) don't direct the water spray into/onto anything that looks electrical or fuel involved.
Peace, out.
Old Mar 9, 2009 | 07:12 PM
z06clif's Avatar
z06clif
Mike Saporetti
Mike
The best way is to never let it get dusty,but if it does I found that a vacuum is OK. Just get up the loose stuff but use the upolstory attachments for the hard to get at places. The brush attachment works good on the flatter surfaces. use a paint brush to stir up the dust and sand and push it to the open hose end of the vacuum. its time consuming . Putting any type of water under the hood makes mud and undesirable water spots. If its grease and oil then thats another story. I use my shop vac. I hope this helps
Clif
Old Mar 9, 2009 | 07:13 PM
VET4LES's Avatar
VET4LES
I blow mine off with air and wipe it with a damp cloth. After four years it still looks like new.
Old Mar 9, 2009 | 07:38 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by z06clif
Mike
Clif
That is about what I do. I also use a rag and detail spray.
Old Mar 9, 2009 | 07:48 PM
cclive's Avatar
cclive
I've never had a problem washing any engine with water and soap etc. The main thing is to NEVER use a pressure washer as it can force water into unwanted places. They say the same thing about motorcycles...never with a pressure washer. I gently get the engine wet, then spray with 409, let it sit for a couple of minutes and wash off. I do it when the engine is warm, not hot but just warm, like about an hour after driving it. Cover the alternator with a rag so it gets no direct spray.
Old Mar 9, 2009 | 08:01 PM
moog5050's Avatar
moog5050
Damp cloth and simple green for any grease spots.
Old Mar 9, 2009 | 08:03 PM
Mad*Max's Avatar
Mad*Max
I use a garden hose selectively, the key is to keep it clean on a regular basis so that it doesn't get too dirty at any given time. I shine it up with Stoners Trim Shine, the engine bay looks awesome. The manual says to stay clear of the air filters which I do.
Old Mar 9, 2009 | 11:36 PM
NW94Z's Avatar
NW94Z
Your engine will get wet when you drive it in the rain. Water will not hurt it if yoru are sensible. Spray the whole thing down with Simple Green. let it sit for 5 minutes. Hose everything with light pressure and start the engine to help dry it faster. It will look almost new.
I've been cleaning LS based engines like this for nearly a decade with zero problems.
Old Mar 9, 2009 | 11:42 PM
humvet's Avatar
humvet
I'm liken this.
Old Mar 10, 2009 | 12:07 AM
CQRT's Avatar
CQRT
I use Simple Green mixed 50/50 on the warm engine . . it's not pertroleum based so there's less to worry about and it'll still cut grease and road grime . . .hose it off gently - - stay away from obvious electrical hubs - - wrap them with plastic wrap or a baggie to be safe.
I use a towel to mop up any puddled water and wipe everything clean - -or you can use the leaf blower approach. Here in AZ, a couple hours in the sun and everything's bone dry.
I user Stoners trim shine or a tire foam product on the plastics and wiring - -but stay away from the serpentine belt. I use the same technique on the wheel wells a couple of times a year after getting it up in the air and pulling off the wheels . . .tire foam works great on plastics as well as metal suspension parts - - but stay away from the rotors!
Good luck-
Old Mar 10, 2009 | 01:04 AM
Atomic-Vette's Avatar
Atomic-Vette
I spray mine down at the car wash about every 10 or so times I wash the car. Just use some common sense and don't get the nozzle too close.
Old Mar 10, 2009 | 01:15 AM
ufso's Avatar
ufso
There's a few things you should also do:
1. Cover with aluminum fold six spots where there is exposed wiring, including behind the battery on the fire wall
2. Cover with plastic the hood shield and tape down with blue tape (keeps it nice looking and water spot free)
3. Hose off lightly
4. Use electric blower to dry
5. Use chamois to get the rest.
I do this everytime I wash the car and as VET4LES says, our engines look as new as the day we bought them!!!
Edit: This only adds about 10-15 more minutes to your washing the car!
Edit Edit: Then Zaino every damn thing in the engine compartment after you've done the rest of the car!!!
Old Mar 10, 2009 | 06:12 PM
msaporetti's Avatar
msaporetti
Default Thanks for the advice.
Thanks guys.
The pressure sprayer apparently was my problem last time. I think I'll use the spray on Simple green and rinse with light hosing with a leave blower dry.
Again Thanks!
Mike Saporetti
Old Mar 10, 2009 | 07:41 PM
orca1946's Avatar
orca1946
Too much pressure will get you into trouble. A light hose spray & cleaner will do fine.
To Cleaning the Engine?
