Removing side markers
Old Mar 20, 2009 | 02:19 PM
petiebear's Avatar
petiebear
Default Removing side markers
I am having a hard time removing my front side markers. They don't seem to want to pop loose. I am afraid to pull to hard. Have any of you done this ? Need help.
Thanks in advance
Old Mar 20, 2009 | 02:29 PM
chucky7's Avatar
chucky7
Thanks in advance
Turn steering wheel to the far left. Remove push pins and small hex head screw from inner fender liner (in front of passenger side wheel) drop panel. reach in and push out lens and holder.
Turn steering wheel to far right. Repeat for driver's side.
Old Mar 20, 2009 | 04:14 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 20, 2009 | 04:41 PM
Jakeross's Avatar
Jakeross
Start at the front of the lens and push out. There are tabs, feel them first to see which direction to push or squeeze them. The front is the hardest part, the back will be easy.
Old Mar 20, 2009 | 04:49 PM
Swiftrider08's Avatar
Swiftrider08
You first need to remove the push-in pins at the leading edge of each wheelwell so you can reach in behind the side marker light. There are two tabs that you can feel. Push the front most tab forward while also pushing outward. When that pops loose, then pull the rear most tab backwards while also pushing outward. They are in there pretty tight, but they will come out.
Old Mar 20, 2009 | 08:19 PM
petiebear's Avatar
petiebear
Got it. Thanks guys
To Removing side markers
