Emergency Brake PROBLEM!!!
Old Mar 24, 2009 | 12:25 PM
Ahmer's Avatar
Ahmer
Default Emergency Brake PROBLEM!!!
Hey Guys, went out to adjust the brake, everything owas fine until I heard a click and noticed the stupid clip fell off its place... any one know a good procedure for replacing this??? I heard someone used zip ties but Im nt sure which cip to put on firstt and when I finally did have them all in I pushed the hinge though and it all fell apart AGAIN!!! AHHHH!!!
Old Mar 24, 2009 | 12:32 PM
Ahmer's Avatar
Ahmer
I just would like some basic instructions on how to do this so I can put my car back together been at it for 2 hours already
Old Mar 24, 2009 | 12:45 PM
cthusker's Avatar
cthusker
What exactly were you adjusting on the brakes? There isn't anything I'm aware of that requires adjustment?
Not sure of your question or what you took apart? A picture would be helpful...
Old Mar 24, 2009 | 02:00 PM
Ahmer's Avatar
Ahmer
basically i pulled the rotor off and found my emergency brake shoe... i procedeed to expand the adjuster found on the parking brake shoe assembly and found that it might have been too tight because when I proceeded to put the rotor on, it got stuck... i proceed to bang the rotor off (with a rubber mallet) and heard a small click, looked behind the rotor and found the parking brake clip hanging there.... man this thing is a PITA to put back together as the clip is a V-shape and nearly impossible to put back on...
I don't jknow what the procedure is to put this back n with...
Old Mar 24, 2009 | 02:05 PM
Ahmer's Avatar
Ahmer
THIS!!!
Old Mar 24, 2009 | 02:08 PM
Ahmer's Avatar
Ahmer
Do I put the entire sping into place and then place the shoe into place and attempt to pry the spring over the clips...
Old Mar 24, 2009 | 02:20 PM
c6 batmobile's Avatar
c6 batmobile
There is a how to on C5 tech if the search function wants to work.
RicK T's Avatar
RicK T
I think you will need help from shopdog or gmautotech. Shopdog is logged in right now, you might want to send him a PM and ask for help.
http://forums.corvetteforum.com/memb...8-shopdog.html
Old Mar 24, 2009 | 03:25 PM
cranky's Avatar
cranky
Originally Posted by Ahmer
THIS!!!
you are in trouble, i had a friend who did the exact same thing. the suspension upper control arm has to be disconnected, the axle slid out of the hub, and the hub and knuckle removed off the car. then the wheel bearing and hub removed from the knuckle. then you can put the retaining spring back on the e-brake shoe. yes, i know it's a pain, but that is the way the shop manual says do it. i know, been there. good luck
Old Mar 24, 2009 | 03:32 PM
RicK T's Avatar
RicK T
Wow....thanks Cranky. I haven't seen this before. I'll save that under "things NOT to do".
Old Mar 24, 2009 | 04:13 PM
C8-Vette's Avatar
C8-Vette
Old Mar 24, 2009 | 04:38 PM
Ahmer's Avatar
Ahmer
OK OK I GOT IT!!!! SO You do slip the shoe on with the wire in place... I then used a zip tie on the top hole and held straight up on it... The next step was tricky and that was holding the center of the V in place and sliding the spring back onto the other tab... took some work but then BAM!!! it was on... i then tightened up the brake and presto!!! no more problems... I took the other wheel off just to make sure I did this one right... WHEEW.
So yes it can be done. Thanks for all your help guys!!!
Old Mar 24, 2009 | 04:40 PM
Ahmer's Avatar
Ahmer
oh and now BTW I have 6 new tiny cuts over both my hands... u really do have to love this car...
Old Mar 24, 2009 | 04:44 PM
bimmerborn's Avatar
bimmerborn
Sorry to hear this happened. Hang it there and you can do it. Let us know how it goes. Good luck.
Old Mar 25, 2009 | 07:54 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Not so.
I made a hook from a piece of brazing rod (coat hanger would work).
Use it to pull the end of the clip on it's tab.
Old Mar 25, 2009 | 11:02 AM
mksz51's Avatar
mksz51
Note to Self: "If parking brake works correctly don't screw with it....................."
Old Mar 25, 2009 | 03:06 PM
Ahmer's Avatar
Ahmer
Indeed, Any slope even 15 degree ones... If I even slammed up the aprking brake ALL the way it would still slide forward and scrape against the curb. I got sick of this. BTW when I did open the assembly I found a WHOLE LOT of brown / black "goo" and grease and nastiness. Nothing like a little purple power action. ALL GONE. Brake are working flawlessly.
Old Mar 25, 2009 | 03:10 PM
B&BVettes's Avatar
B&BVettes
You got that right
To Emergency Brake PROBLEM!!!
