CoilOver ?
the Pfadt coilovers have springs that are 50% stiffer than stock...everyone's tolerance is certainly different, but that's going to have a lot more impact on daily driving comfort than adjustable shocks/sways. Sways have little effect on daily driving comfort and adjustable shocks can be easily set for comfort or performance (at least the Pfadts are very easy to adjust).
Price-wise, you could also consider something cheaper than the Pfadt sways...Hotchkis bars are far cheaper (though not nearly as stiff as the ones linked above...those are crazy stiff)
Joe
Now to the real heart of the matter, tires. Good tires are more than rubber bands wrapped around oversized aluminum wheels. Good tires act as air suspension members. To do that efficiently, they need to have adequate sidewall height and compliance. Look at the tires on a F1 or Indy car. They have at least a 50 profile, and their height and width are nearly the same, IE they are in a sense "square". This is ideal. The tires on our cars were chosen more for show, allowing a very large flashy wheel to dominate the wheel tire combo. But that costs us sidewall height and our tires wind up being mere rubber bands wrapped around an oversize wheel, like the wheels of a 19th century wagon or stagecoach. Not good.
Because we must have brake clearance, we can't drop our wheel sizes down enough to achieve the ideal "square" profile (F1 and Champ cars use inboard brakes, both to allow smaller diameter wheels and to reduce unsprung weight). But we can go to 17 inch wheels all round, and up the tire profile to at least 40. That provides a very noticeable improvement in ride, and helps with launch at the drag strip (especially if using wrinkle wall slicks).
Larger bodies/pistons have pros and cons... like just about everything.
The adjustable damping on our coilovers allows you the user to control the ride quality to a large degree. The damping can be used to fine tune car balance and handling, but most use it to meet their ride quality goals. Our springs are stiffer than stock, but that is because we think these cars can stand a significant amount more spring than the factory puts on. There are some practical limitations that GM faces with the fiberglass leafs in terms of rate. Even the T1 spring package is only 10% stiffer than a Z06 rate. Our coilovers are 30 to 40% stiffer than Z06 leafs. Most people will tell you that they love Pfadt coilovers on the street.
Our staff is always available to help you determine which of our many suspension options will suit your needs. Feel free to call us for advice anytime.
In terms of noise, all products are susceptible to improper installation. Improper installation can cause noise. Our coilovers are not noisy, and if you have a set that is, you should visit your shop or call us directly. There are several easy things to check if you have some noise. We're happy to help you diagnose any product issues.
In the mean time if you are local to SoCal or willing to drive their pm me for a great price from a local forum vender. They are only doing the deal parts & labor but it is well worth it.
Joe
Joe
Joe
Having driven the porsche twin turbo, I am looking for a less clumsy ride, something more confidence inspired on turns with bad road imperfections. I would also like the car to feel light like it really is. I will say the Acura RSX feel more confidence inspired in turns with road imperfections and it feel nimble and light but solid.
Trust me I know my Z06 handles way better than the Acura but I am talking about the confidence I feel in the RSX or the Porsche. I have been driven nothing but stock vette's since 1994 from C4-C5-C6-C6
_Z06 so I do not know the cure and this is my first time modding.
Will coilover cure this help this or not gonna get me what I want? Or do I just need to get the shock? I feel like the cars dampening is pretty tight on compression but on expansion or rebound it gets really floaty for a sports car.
I HPDE once or twice per year and the car is a daily driver. I live in LA & the local roads are really bad, so I do not want he car to get more harsh this is why i was thinking adjustable. I can tighten it down for canyon and DE runs.
Please excuse my ignorance as I am not a wrench type but I love to drive.
Joe
I explanined what my intensions were for the car and how I used the car normaly. I ended up buying his complete Penske 8700 soultion and for what I'm doing 10 + HPDE's per year and agressive rally events I have the very best solution I could ever have. However I have some friends that don't do any real track events but enjoy the track for a stress releif at NASA events and other Car OEM days and he went with a much less expensive solution, and he's extremely happy with what Gary and he put togther.
With my experiance I can only say this call Gary talk to him you will get information that realy means allot and is simple to comprehend.
Ernie O
The Pfadt instructions recommend starting with the front and rear at the same adjustments for street driving. I have also seen a post by Pfadt where it's recommended to set the front at 2 and the rear at 10 for the drag strip to gain more traction. So - the versatility is definitely there. I am having fun with the adjustments and can't wait to get my car on the track to do further "research."
I did switch out tires as well but stayed with the runflats. Since the the Michelin PS2 ZPs were designed for the ZR1 and showed impressive results on the track, I thought I'd try them out. So far the warmest I've had for outside temperatures is 54 degrees. The jury is still out but summer is just around the corner.
Don't misconstrue my meaning...I've seen some very fast, capable Corvettes on a stock suspension but I still think a coil-over suspension is superior to the transverse leaf spring setup. The independent suspension has IMO a more planted feel than you get from the transverse leaf spring and to borrow a phrase...less "cross-talk" than you get with the transverse leaf spring suspension.
My advice: Get non-run flat tires, Koni FSD or Bilstien dampers and take driving lessons and learn to drive the car you have before dropping that kind of money. I learned a very important lesson learning to drive fast, and taking lessons at the Nurburgring; it’s not the car it’s the driver.
T
T
I totally agree that training the driver is key. I am training every time I am out there and I am sure I have a lot to learn. I am not looking for these to increase my laptimes. If they do that is great. I am looking for a more confidence inspired ride. I could care less about laptimes as I do the DE's for fun.
The car feels tight on compression and does not roll too much, it is that I just can not stand the fact that a 60-70k dollar car feels floaty on re-bound. It also takes time to regain composure once the suspension has been unsettled. My wifes prius does not feel near as floaty. Stock suspension just larger rims & tires.
Joe
Joe this is a post that is current right now on the forum.
http://forums.corvetteforum.com/c6-c...post1569462343
