Torque Specs
Old Mar 26, 2009 | 09:55 AM
6speedC6's Avatar
6speedC6
Default Torque Specs
I tried the search engine but I couldn't find anything.
Anyone have the specs for the caliper mount and calliper bolts
Old Mar 26, 2009 | 10:01 AM
BEZ06's Avatar
BEZ06
Here's the source you need for all torque specs (and much more!):
http://davidfarmerstuff.com
Bob
Old Mar 26, 2009 | 10:48 AM
6speedC6's Avatar
6speedC6
Thanks much. Great Info!
Old Mar 26, 2009 | 11:14 AM
Capt Steve's Avatar
Capt Steve
Tighten the caliper bracket bolts to 129/ft lbs. Tighten the caliper guide pin bolts to 23/ft lbs. Tighten the brake hose inlet fitting bolt to 33/ft lbs.
Old Mar 26, 2009 | 11:22 AM
Wayne O's Avatar
Wayne O
CF Senior Member
FWIW I believe the service manual states the caliper bracket bolts should not be reused. I'm not suggesting you do otherwise but I've resued the caliper bracket bolts on numerous occasions and never had any problems.
To Torque Specs
