How do i remove chicklets? Ty.
Old Mar 31, 2009 | 12:59 PM
gene0809's Avatar
gene0809
Default How do i remove chicklets? Ty.
Time to remove ....thanks
Old Mar 31, 2009 | 01:15 PM
Jakeross's Avatar
Jakeross
Use unwaxed dental floss. It's cheap and saws the chicklet off cleanly.
Old Mar 31, 2009 | 01:33 PM
mksz51's Avatar
mksz51
Clean up residual "stuff" after flossing with WD40 - let it soak a bit and roll the stuff off your paint with your finger. Rewax area and you are done.
Old Mar 31, 2009 | 01:36 PM
gene0809's Avatar
gene0809
THANKS ALL
Old Mar 31, 2009 | 01:37 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I heated them up using a hair dryer first to loosen the glue, then took some fishing line and "sawed" back and forth until they came off. I then used Goo-Gone on the residue left behind and it looks as good as new.
Old Mar 31, 2009 | 03:08 PM
CO Lightfoot's Avatar
CO Lightfoot
Before I got my 09, I read several posts on removing chicklets. Easy, right? Here's what happened to me:
Attempt #1: Tried dental floss, the floss broke, the chicklet didn't loosen or budge at all.
Attempt #2: I carefully tried to lift the chicklet off with my finger. Bent a fingernail backwards.
Attempt #3: A bit pi$$ed after #2, I considered using a hair dryer to soften the glue, my weed-wacker plastic line to lift-off the chicklet, maybe even a spackle knife or screwdriver...
...been down this road before. (You should see what I did to the lid on my Zaino bucket.) No need to risk damage to my brand-new C6.
My chicklets remain installed just the way they left the factory.
Anyone think maybe GM switched to a stronger glue?
Old Mar 31, 2009 | 03:19 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Fishing line is better. I first tried sawing them off with dental floss and broke the line several times. Heating them up first really helps too.
Old Mar 31, 2009 | 03:20 PM
loubob57's Avatar
loubob57
Another method is to stick a business card or equivalent piece of cardboard under one edge and pry up on the opposites side. The card keeps the edge of the chicklet from digging into the paint and denting it.
Old Mar 31, 2009 | 03:24 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
no NO no KEEP THEM ON they are standard equipt.
Old Mar 31, 2009 | 03:29 PM
knick's Avatar
knick
replace em' witha mini z51 chiklet
Old Mar 31, 2009 | 03:31 PM
Road Rage's Avatar
Road Rage
Pretty sure President Goodwrench isn't going to like you removing the chicklets.
Old Mar 31, 2009 | 03:34 PM
vetdude's Avatar
vetdude
Can hear the commentators on Barrett-Jackson 30 years from now - this Corvette even has the original chiclets still installed!!!
Removed mine a couple of years ago to reduce drag. The cars do look better without them - cleaner.
Take note of the arrow on the opposite side after removal to ensure the line workers don't install them upside down.
I understand that GM is quickly replacing the GM logo on the chiclets with President Obama's face for all future builds.
Old Mar 31, 2009 | 03:45 PM
dvilin's Avatar
dvilin
There goes your GM Warranty.
Old Mar 31, 2009 | 03:49 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Took me 5 min to take mine off... I heated them up with a hairdryer... used fishing line to remove.... got some adhesive remover to get off the residue...and replaced the chicklet....
Old Mar 31, 2009 | 03:55 PM
gsport's Avatar
gsport
mine are still on... why would anyone want to make their car look like an '05....
Old Mar 31, 2009 | 04:18 PM
mksz51's Avatar
mksz51
[QUOTE=CO Lightfoot;1569518057]Before I got my 09, I read several posts on removing chicklets. Easy, right? Here's what happened to me:
Anyone think maybe GM switched to a stronger glue?[/QUOTE]
No - I'm thinking you maybe just aren't the mechanical type.
Old Mar 31, 2009 | 05:19 PM
p35hp's Avatar
p35hp
And I should care? Now, if he wants to replace the savings I withdrew to buy the C6, he can pick the color!!
To How do i remove chicklets? Ty.
Old Mar 31, 2009 | 06:27 PM
turmat's Avatar
turmat
Dental floss and goo gone. Off and clean in less than 45 minutes.
Old Mar 31, 2009 | 07:29 PM
RanGer498's Avatar
RanGer498
Old Mar 31, 2009 | 07:37 PM
hot4u's Avatar
hot4u
