Do Gorillas work for GM????
Removed the drain plug with no problem. The autoparts store down the street had the correct fluid in stock too.
What does that say when a GM Dealership doesn't even stock what they need to do common jobs.
I know I could have had it done free under warrantee but the piece of mind knowing it was done right................................... ...priceless.
That plug should have ben removed before you got that car as the dealer got the car ready to go, just to amke sure it was full, but none of them do it.
When I checked my new truck it was low by 4 pints, and then later I saw a TSB about bad rears on those trucks, caused by low fluid levels.
On the other hand, the drain plug came off fairly easily.
Ok, my trip thru Bowling Green was about 1991, but at that time about all I saw was hand tightening or power electric drills to drive screws and small nuts. I don't remember seeing a slip clutch on any power tool. The tire power driver probably did have a torque stick on it, but that was about all I saw.
I lagged behind and talked to one guy on the line. He was putting brake parts on. You know, the parts in the service manual that have all those 'critical' warnings and 'failure to follow these procedures may cause loss of life' warnings. This guy had a line wrench where the head (wrench) part had been cut off and re-welded onto a straight handle a couple of inches longer than you would get on a store bought line wrench and wrapped with some kind of cushioning tape. He was putting the brake lines on the calipers. He just tightened down by hand. No measuring tool at all.
In trying to talk to him, his only comment was how the bosses had cut back on overtime shifts. Not letting anyone make any money. I didn't try to tell him if no one was buying the cars, those 'bosses' sure didn't need to be running overtime making even more of them.
Overall, during this time, I thought the line was very scary. People smoking all over the place, except where they were using flamible adhesives, radios blaring at many workstations, and as I said, hand tools or 'regular' power tools putting things together.
I saw the 'first start' of a car. The car was still in the air, and a guy put his but into the car and plugged an electronic box into the electronics test plug and proceeded to run a few tests. The lights came on and off and he started the car. He put it into gear, an automatic, and of course the tires turned since it was in the air. Did a few other tests or whatever. Then, while the car was probably running at least 800rpm or so, he moved the shift from drive into park. The park powl (sp) screamed as it tried to lock the transmission. I really don't think this was a test, I think the guy was just too lazy to pull his foot into the car and push the brake to stop the rear tire spin, he just jammed it into park.
I've read other peoples description of current visits on the assembly line where they talked about the care taken in building the car. I just hope it's true. From my trip in 1991, there was room for huge improvements in how they put these cars together, and the attitude of the workers.
